Old 05-02-2018, 10:45 PM   #1
my56chevytruck
my56chevytruck's Avatar
new grey wheels
OK, this has been hashed over a few times, but my situation is I need help finding a set of wheels that match my suspension. I'm wanting a complete set of wheels front and back that go on my 56 chevy truck, with a 2nd Camaro suspension/rear end. I have 15" wheels on it now, and what I am wanting is grey spoked mag wheels, 15x7's with 4.50" back spacing. I'm not aware at this moment what my offset is, but I know I would like to find wheels based upon my current measurements and desires. So as you can see, I'm needing your help, can you locate a name of wheel I can look at for my truck? I've looked at American Racing and Vision wheels, they are close, but I cannot find the 4.5" backspacing I need. I'll thank you in advance. Pictures would be greatly appreciated.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 05-02-2018, 11:44 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: new grey wheels
Try Coys, Boss 338's
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 05-03-2018, 12:00 AM   #3
59chev
59chev's Avatar
Re: new grey wheels
Not sure about the backspacing but look at Rocket Racing Wheels..
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 05-03-2018, 03:12 AM   #4
MiraclePieCo
MiraclePieCo's Avatar
Re: new grey wheels
I entered your parameters (15 tall, 7 wide, 4.50 backspacing, Chevy lug pattern, grey color) into Summit Racing's wheel selector and found four choices. Play around with the options, you may find lots more - for example unilug pattern may bring up many more options:
https://www.summitracing.com/search/...7%2B4294920801
MiraclePieCo is offline   Reply With Quote
Old 05-03-2018, 08:10 AM   #5
Jemezcrusher
Re: new grey wheels
I got custom backspacing on my torque thrusts from Discount Tire
Jemezcrusher is offline   Reply With Quote
Old 05-03-2018, 09:14 AM   #6
my56chevytruck
Re: new grey wheels
thanx Dan, I'll try them.
1940 Ford Dlx Coupe
1969 Mach1
Old 05-03-2018, 09:15 AM   #7
my56chevytruck
Re: new grey wheels
I'll check that option out.
1940 Ford Dlx Coupe
1969 Mach1
Old 05-03-2018, 09:16 AM   #8
my56chevytruck
Re: new grey wheels
this is why we ask for help, you guys are there to assist. Thanks
1940 Ford Dlx Coupe
1969 Mach1
Old 05-03-2018, 12:56 PM   #9
Dan in Pasadena
Re: new grey wheels
It’s looking like I’m gonna need to buy custom backspacing too. I bought used Boyds because they were uber cheap, had them polished, etc and now that I am putting my bedwood on it’s apparent the inside tire sidewall is too close to the wood, and this is without the bedside being on! I’ll use washers to determine how thick a spacer will work but I really don’t like the idea of using spacers long term. Once my bedsides & fenders are on I’ll be able to accurately determine the backspacing and maybe get a wider rear wheel under there. Besides, I want gray spokes too!
Old 05-03-2018, 04:22 PM   #10
mr48chev
mr48chev's Avatar
Re: new grey wheels
The 15 x7 with 4.04 comes closest on a 5 spoke . http://www.americanracing.com/wheel/...torq-thrust-ii
If you go to 8 inch wide you can get deeper back spacing.
My ongoing truck projects:
Old 05-04-2018, 12:35 AM   #11
my56chevytruck
Re: new grey wheels
Dan,
I'm going to go with a set from Rocket Racing (thanks to 59CHEV.The truck I have is grey and the style of wheels is also grey. How much room do you have between your bed and outside fender lip? What style/color of wheel are you looking for? Look up Rocket Racing wheels as well as Vision wheels.
1940 Ford Dlx Coupe
1969 Mach1
Old 05-04-2018, 06:27 PM   #12
59chev
59chev's Avatar
Re: new grey wheels
Great to hear! I think those will look great on your truck. I was seriously considering the "Rocket Fuel" for my build until I found a set of powdercoated z28 5 spoke rallys that I couldn't pass up.
Which ones are you getting?
Old 05-04-2018, 09:57 PM   #13
Dan in Pasadena
Re: new grey wheels
... How much room do you have between your bed and outside fender lip? What style/color of wheel are you looking for? Look up Rocket Racing wheels as well as Vision wheels.
Glad you found some you like.
I have no idea how much room I have because my bed hasn't been together since I tore it down for paint. But I DO know that the inner tire sidewall is too DAMN close to the wood so it will be even closer to the bedsides, maybe touching - I'll have to do something, I just don't know what yet. The bedsides will go on tomorrow (fingers crossed) and the fenders next week - they're still at the painter's shop.
Basically, I like the classic five spoke Torq Thrust. I have to have at least 16's to clear my front calipers but since there isn't much tire selection in 16's I will go with 17's. I also really like Salt Flat wheels but probably not enough choose them over classic TT's.
Old 05-05-2018, 10:59 AM   #14
Black_Sheep
Black_Sheep's Avatar
Re: new grey wheels
Dan your truck looked great with Torque Thrust wheels on it. They are available in 17” which should clear all but the biggest brake kits without looking too big.
Black_Sheep is offline   Reply With Quote
Old 05-06-2018, 10:17 PM   #15
my56chevytruck
Re: new grey wheels
I bought the Rocket Racing Fuel Gray's. of course they have to order them now, will take about 3 weeks to get them.
1940 Ford Dlx Coupe
1969 Mach1
Old 05-06-2018, 10:19 PM   #16
my56chevytruck
Re: new grey wheels
I highly suggest you talk to Summit Racing on their technical service line, 330/630-0240. With the right backspacing and offset you should be fine. Good luck Dan
1940 Ford Dlx Coupe
1969 Mach1
Old 05-06-2018, 10:21 PM   #17
my56chevytruck
Re: new grey wheels
Thanks again for your help.
1940 Ford Dlx Coupe
1969 Mach1
Old 05-11-2018, 04:57 PM   #18
my56chevytruck
Re: new grey wheels
I want to thank you 59chev for your wheel recommendations. I got my Rocket Racing wheels the other day thru Summit Racing and mounted them today. The tire selection I made was going from 235/75/r15's in the rear to 255/60/r15's but stayed with the 215/70/r15's in the front. Due to the 4.25" backspacing all around, i'm thinking the issue of front tire rub will significantly be eliminated
1940 Ford Dlx Coupe
1969 Mach1
Old 05-12-2018, 12:47 AM   #19
59chev
59chev's Avatar
Re: new grey wheels
You are welcome. Glad they worked out. Looks sweet on your truck!!
