Old 05-05-2018, 11:22 PM   #1
mehoff400
Gauges - what are you running?
i currently have stock gauges the speedo doesnt work nor the fuel gauge. well what are you guys running? i was thinking something aftermarket
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 05-06-2018, 01:41 AM   #2
Ken Cook
Ken Cook's Avatar
Re: Gauges - what are you running?
Restored factory gauges with tachometer and vacuum gauges. With the amp gauge converted to volt gauge.
I really like the way they came out and I didn't have to buy a new wire harness.
I had the same as you, a speedometer and fuel gauge that didn't work and the rest were just lights. I bought a gauge cluster on ebay and had RedlineG add the tach and vacuum gauge.
Ken Cook is offline   Reply With Quote
Old 05-06-2018, 02:36 AM   #3
luvbowties
luvbowties's Avatar
Thumbs up Re: Gauges - what are you running?
Ken, those oem gauges really look nice, plus take up NO extra space.
Sam
luvbowties is offline   Reply With Quote
Old 05-06-2018, 09:08 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Autometer
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-06-2018, 10:53 AM   #5
Pinchecharlie
That is sweet!!!!
I just bought a stupid expensive vhx shi@ and now wish I had this! Oh well
Pinchecharlie is offline   Reply With Quote
Old 05-06-2018, 11:24 AM   #6
LVPhotos
LVPhotos's Avatar
http://67-72chevytrucks.com/vboard/s...=371684&page=5
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-06-2018, 11:29 AM   #7
Ken Cook
Ken Cook's Avatar
Originally Posted by Pinchecharlie View Post
That is sweet!!!!
I like it because most people think it's original to the truck.
The guy had me send the temp sending unit so he could calibrated the gauge to it. Now I know for sure my temp is correct.
He also gave me choices on where the volt gauge would zero at. It could have zeroed pointing straight up so that when the key is off it would look like a stock Amp Gauge but I had him do the full sweep. I also had him add the numbers to the face.
The tach is an original GM part that he converted to 6-cyl, not one of the aftermarket tachs that only work with a V-8.
I also know now that my fuel sending unit is going bad. I wasn't sure if it was the gauge or the sender. I thought it was the gauge but now I KNOW it's good. Now I can order the sender and know I'm not buying parts I don't need.
Old 05-06-2018, 11:32 AM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Here's another thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=371684
66 C20 Service Truck:
Old 05-06-2018, 12:20 PM   #9
LVPhotos
LVPhotos's Avatar
Engine turn panel from Hayline, SoCal gauges
Old 05-06-2018, 07:03 PM   #10
vin63
It's Better With Nitro
vin63's Avatar
Autometer and Pac Brake for the air pressure gauge...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-06-2018, 08:27 PM   #11
The Rocknrod
Moderator
The Rocknrod's Avatar
Stock all new rebuilt with new volt meter, oil sender, fuel sender, tachometer, temp sender, clock. Ooooew we stitch jones.
Old 05-06-2018, 08:31 PM   #12
stsalvage
Scrapper 1
stsalvage's Avatar
How much dose that set up for the 1964-66 The one under me with the Clock an tack can this be used with the LS engines
stsalvage is offline   Reply With Quote
Old 05-06-2018, 08:32 PM   #13
stsalvage
Scrapper 1
stsalvage's Avatar
It looks cool for my 1964 short bed fleet side big window
Old 05-06-2018, 09:42 PM   #14
Pinchecharlie
Damnnnnnnn! Sometimes you just gotta do what it takes! Thats sweet as!
Old 05-07-2018, 12:52 AM   #15
nimrod
nimrod's Avatar
Love the engine-turned stuff!
nimrod is offline   Reply With Quote
