Old 05-08-2018, 03:34 PM   #1
PORKY
PORKY's Avatar
Pinion angle severe but seems to be stock
I’m getting back to work on my 1965 short box Fleetside Chevy. I have put new stock rear springs and bushings and it has a 295-50-15 Tire. The spring perches appear to be stock. The weld certainly looks factory. I have a 15 degree pinion angle, with the pinion pointing up towards the tranny. This is severe to me. The tranny angle is approximately 8 degrees pointing down towards the rear differential. I realize I need to pick the engine and tranny (zz427 & Tremec TKO600) up a few degrees. The front height of the truck is without the front sheet metal on it. But this certainly can not change the pinion angle that much. The truck originally had a 6 cyl. engine with a 3 on the tree. The front springs are new stock too. I feel I am missing something obvious and stupid. The angle is so severe the only fix seems to be to cut and change the perches. Has anybody seen such a severe pinion angle from the factory? I have attached a couple of picks showing the angle and the current stance.
THANK YOU!
PORKY is offline   Reply With Quote
Old 05-08-2018, 11:39 PM   #2
Captainfab
60-66 Nut
Re: Pinion angle severe but seems to be stock
The truck appears to be sitting rather high. I'm thinking once you get everything installed on the truck it should drop down a bit which will reduce your current pinion angle.
Old 05-09-2018, 12:19 PM   #3
TopFuel1966
TopFuel1966's Avatar
For a 2WD half ton it seems like it has an excessive amount of ground clearance. Are you sure you have the correct springs and shocks?
TopFuel1966 is offline   Reply With Quote
Old 05-09-2018, 01:49 PM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
that is excessive. ...around 3deg is about average on trans and rearend. ...and I agree...it looks to sitting high...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-10-2018, 06:40 AM   #5
PGSigns
PGSigns's Avatar
The new springs are not wound like the old progressive springs. That may make them a bit taller. Also there is the heavy duty spring that is for the Suburban that will give you just what you have going on. The truck will settle some as you get all the weight on it but I dont think it will go the 3 inches it needs to get you a good pinion angle.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-10-2018, 07:05 AM   #6
PORKY
PORKY's Avatar
Thank you all very much for your replies & the help. The Springs were all ordered as stock springs for a 1965. Can anybody tell me what the stock height should be so I can measure it?
Thanks again for all the input!
Old 05-10-2018, 08:15 AM   #7
nsb29
nsb29's Avatar
They look like the springs from my friends suburban
nsb29 is offline   Reply With Quote
Old 05-10-2018, 11:25 AM   #8
Duncan K
My 66 GMC was sitting around 10 degrees with what i believe were the stock springs.
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 05-10-2018, 04:16 PM   #9
mongocanfly
Post Whore
on these model trucks, are the 3 center coils not supposed to be nearly touching each other?like in this thread pics......http://67-72chevytrucks.com/vboard/s...d.php?t=763522 .....his are spread out...
Old 05-10-2018, 11:27 PM   #10
Captainfab
60-66 Nut
As stated in that thread, the OP there has what is known as progressive, or variable rate springs. Those were available from the factory although what the OP in that thread has likely have settled a bit from it's original height.
