Old 05-11-2018, 06:26 PM   #1
mfm3
Pinion angle correction with drop blocks/bags
Did a search but did not find any info on this specific topic.
I have 2" drop blocks and bags in the back for approx 7" of total drop. Need to correct my pinion angle about 5 degrees. Does anyone know of drop blocks that also correct the pinion angle? If not, I have an extra set of 2" aluminum blocks that I will have machined to provide 5 degrees of correction.
The picture shows the outline of the 2" block. The red area shows an example of how machining an angle on the top side of the block could double a pinion angle corrector. Other ideas are appreciated.
mfm3 is offline   Reply With Quote
Old 05-11-2018, 07:13 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Pinion angle correction with drop blocks/bags
https://www.speedwaymotors.com/Leaf-...l?sku=916433-4
https://www.speedwaymotors.com/Rear-...hoCDYYQAvD_BwE
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-11-2018, 11:43 PM   #3
mfm3
Thanks LV. Those are perfect.
Old 05-12-2018, 07:45 PM   #4
PGSigns
PGSigns's Avatar
I machined 2 1/2 degrees off the top of mine worked perfect.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-12-2018, 09:55 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
CPP makes them in a drop block also.
Old 05-13-2018, 02:26 PM   #6
mfm3
Thanks...CPP's only option is 4 degrees which is probably good for most situations. $80
http://www.classicperform.com/Store/2016/CP39028.htm
