05-12-2018, 12:34 AM | #1 |
Steering shaft upgrade: how can I tell what year column I have?
I have a '73 C20. I swapped the steering column and everything above the rag joint a while ago because of problems with the ignition linkage.
My impression is that you can only do the XJ shaft on later square bodies. Is there an easy way to tell if my column is newer?
1973 C20, 350/350 |
05-12-2018, 02:26 PM | #2 |
Re: Steering shaft upgrade: how can I tell what year column I have?
with that single bolt going thru it, looks like you can do the xj shaft on it. not sure if your steering box will be the right spline though.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-12-2018, 03:43 PM | #3 |
The writeups I saw said that all squares have the same steering box splines so I think it should work.
1973 C20, 350/350 |
05-12-2018, 09:59 PM | #4 |
Steering box is not the same. I have a 74’ and the XJ shaft won’t fit my box
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
05-14-2018, 10:20 AM | #5 |
If you take your shaft out and replace it. what you doing with the old shaft. ?
The rubber seal not ripped or cracked.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
