Old 05-12-2018, 09:33 AM   #1
blazer2007
water pump leak
350 motor. Have a small drip when motor is warm on lower bolt not the weep hole can see it from that bottom bolt, was a bit loose but still leaks a bit not much but still a leak. Is that bolt going into a water jacket ?
blazer2007 is offline   Reply With Quote
Old 05-12-2018, 02:25 PM   #2
v30crewcab
v30crewcab's Avatar
Re: water pump leak
I believe you need a little sealant on the bolt threads.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-13-2018, 09:09 AM   #3
blazer2007
Re: water pump leak
That did the trick no more leak
