05-13-2018, 01:38 PM | #1 |
Lower ball joint install
Just curious if you guys press them in or will tightening the nut onto the spindle press it in? What method do you guys use. Thanks
05-13-2018, 01:44 PM | #2 |
Re: Lower ball joint install
If you want to own tools like I do, buy a Harbor Freight balljoint press. If you just need to Git-R-Done, rent one from the parts store you buy the balljoints from. A lot of them loan the tools, you just leave a deposit.
05-13-2018, 01:49 PM | #3 |
Post Whore
Always pressed mine in. The other way I have never heard of. You would have to fabricate some kind of spacer to fit between the bottom of the spindle and over the top of the ball joint. Tighten it down then remove the spacer and assemble the boot on the ball joint. It seems like a bunch of extra work to me. But others may have tried it.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-13-2018, 02:24 PM | #4 |
I use an OTC 7249 ball joint press. It also works well on U-joints. And they are only about $105 online. Not a bad price for a made in the USA tool. They are very good quality.
05-14-2018, 12:12 PM | #5 |
Must use a press to do it correctly and safely.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-14-2018, 02:37 PM | #6 |
I just did mine with the rental tool from the local parts store. I can't imagine any way in which tightening down the ball joint nut on the spindle would pull the balljoint into place.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
05-14-2018, 04:40 PM | #7 |
I have a Snap On BJP1 but I am a tool junkie.
Trying to pull the joint in with the nut will be a disaster.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
05-14-2018, 05:22 PM | #8 |
If you have the lower control arm off, you can use a regular bearing press.
05-14-2018, 05:34 PM | #9 |
Smarty pants...
05-15-2018, 10:14 AM | #10 |
place the lower ball joint in its hole and lift the weight of the truck with the jack on the ball joint. The take your BFH and hit the control arm until it is seated.
05-15-2018, 10:29 AM | #11 |
I was having some trouble with mine, kept slipping on the press, so I took them to a trusted ancient mechanic who has every tool, device, and press known to man. He actually has a lighted SnapOn display cabinet they gave him with pullers and presses.
He promptly took a big f'n hammer and whacked it 3 times and it was in. Protect the bolt, that's all I remember! I actually have a ball joint press and I know he has the same one, but the hammer seems to work for the lowers especially well.
05-15-2018, 12:00 PM | #12 | |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
