05-14-2018, 04:04 AM | #1 |
Idle stop solenoid info
I’m trying to get my 84 back to complete functioning condition. I just recharged the ac, it’s holding pressure and blowing cold air. It was missing the idle solenoid so I purchased a standard es110 off of eBay. The only thing I’m running into is the solenoid won’t raise the idle, it will only hold the idle higher if I have the ac on, then give it gas and then when I let off it will hold the higher idle speed. Basically it seems the solenoid is a lil bit weak to me or is that how these are actually designed to function?
05-14-2018, 05:48 AM | #2 | |
Re: Idle stop solenoid info
There is another type of solenoid used with Q-jets. Called an "idle stop solenoid" and that was used in a primitive attempt to prevent dieseling (i.e. run-on). I believe the part was actually the same - but it functioned and was mounted on the carburetor differently. Rather than bump idle up upon an increase in load, it would reduce idle. Also, I am pretty sure it only was installed in trucks with manual transmission applications: |
05-14-2018, 05:58 AM | #3 |
https://www.summitracing.com/parts/s...olet/year/1984 Maybe it’s not correct but everything bolted up and lined up correctly. I was under the impression that when the ac was activated it would kick the idle up. The wire that runs to it is energized when the ac is turned on. Problem I’m having is that it won’t kick the idle up, it will hold it at a higher rpm if I give it throttle and then let off. Maybe that’s correct for these trucks, I just wanted to make sure there wasn’t anything wrong with this one. |
05-14-2018, 06:24 AM | #4 |
Maybe your return spring is too strong. Or your linkage too tight?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-14-2018, 09:43 PM | #5 |
How is it wired? The harness on the firewall has two terminals. One for the clutch that kicks in and out and one for the idle solenoid that has constant power when the ac is on.
I’ve never known them to be able to push the throttle open, only hold it open when energized. You will have to open the throttle to allow the solenoid to move when the ac is first turned on, but it will hold the idle higher as long as the ac is selected.
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
05-14-2018, 10:36 PM | #6 |
I have one on mine that operates the same way. It is not strong enough to increase Idle when AC is turned on without a little press on pedal. After that works great and has been working very well. I thought it was bad when I installed last year, but searched info online and found out this is normal.
Still glad I have it.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
05-15-2018, 04:07 AM | #7 |
