05-15-2018, 07:50 AM | #1 |
1963 project truck
Hey everyone. Just wanted to introduce my project. I have a 1963 c10 long bed fleetside with a 230 i6 and sm420 4 speed. Truck has been in my family for almost 30 years and has been my grandpa's daily driver up until a year ago.
As far as project goes it will be done in stages. First stage is going through, making sure everything is up to par to be safe to drive, and a basic small block and different manual trans...t5 maybe? Not sure the best route to go there. Just keeping it pretty simple for now as I'm expecting my first kid this fall, and don't have a place to do the full restoration right now. Future plans include full restoration, updated suspension front and rear with full disk brakes, and big block. Truck will be lowered on coil overs...not slammed. And I will be making it a short box. And yes the truck has an 80's bed on it at the moment...my grandpa put it on |
05-15-2018, 08:32 AM | #2 |
It's Better With Nitro
Re: 1963 project truck
Welcome! Looks like a great project with a lot of sentimental value. This forum is a great place to help with your build up. I'm a little partial to '63s.
05-15-2018, 08:52 AM | #3 |
Thank you. I remember playing in this truck when I was a little kid, I Nick named it the beast when I was about 6 years old haha. And yes I find myself partial to the 63's as well
05-15-2018, 01:07 PM | #4 | |
https://lugnutz65chevystepside.weebl...ter-plate.html http://www.hotrod.com/articles/1201c...tall-underside |
05-15-2018, 11:44 PM | #5 |
60-66 Nut
Welcome to the forum
Sounds like you have a good plan. An OD trans is a good choice for these trucks.
05-16-2018, 12:51 PM | #6 |
Thanks. I'm kind of undecided on the trans right now. I'm thinking either t5 or a Muncie m20 or m21 if I can get my hands on one. Just worried about the strength of the t5. My small block will probably end up at about the 300 ft. Tq. mark, nothing crazy, but I'm pretty sure the t5's are rated for less than that
05-18-2018, 07:59 AM | #7 |
I have the sm 420 trans behind the 230 i6, Would trans, bellhousing, starter, and flywheel bolt right up to my chevy 350? If so I might throw my stock 350 in this weekend
05-18-2018, 09:35 AM | #8 | |
http://www.britishv8.org/articles/bo...t5-id-tags.htm |
05-18-2018, 09:50 AM | #9 |
Thanks 64stpside, good info in there. I probably will end up going t5 in the future. For right now it seems like everything in the truck should bolt to a 350 so I'm thinking of dropping my stock 350 in this weekend. Then do the t5 when I finish my mild 350
05-18-2018, 11:01 AM | #10 |
1965 Chevy C10, 2005 4.8L/4l60
Welcome!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-18-2018, 11:38 PM | #11 |
60-66 Nut
Yes, everything will bolt up to your 350, The same motor mounts and motor mount location. You will want to change the radiator to the V8/HD cooling radiator that sits on top of the frame and right up against the radiator support. If your 350 is a '86 and newer, you will need a different flywheel.
