05-15-2018, 11:03 PM | #1 |
1977 C10 Gas Gauge
First time posting. I have a 1977 C10 and the gas gauge is on the fritz. A few weeks ago the gauge pegged itself way past full and stayed there for a few days. One day I started the truck and the gauge slowly went back down to around a 1/4 of a tank which seemed about right. All was well for a few weeks until the other day it pegged way past full again. This time it only lasted until I started it again. Then tonight it did it again, went way past full and stuck.
Any ideas? Is this the sending unit or something (fingers crossed) more accessible like a fuse? Thanks all in advance for the help |
05-16-2018, 01:29 PM | #2 |
Re: 1977 C10 Gas Gauge
Gas gauge reading at 3 o'clock is almost always a bad connection somewhere between the gauge and the ground stud off the sender on the tank.
Open circuit - 3 o'clock reading. Wire shorted to ground - empty reading. 41 year old wiring has lots of places for corrosion to do its thing. If dual tank, switch is also a prime suspect. |
05-17-2018, 11:12 AM | #3 | |
Moderator
The sender ground is damaged or missing. The tank strap is making intermittent contact with the tank making the gauge work intermittently. Clamp a jumper cable from the tank pinch weld to a clean spot on the frame and watch the gauge work normally.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 05-17-2018 at 01:33 PM. |
