05-16-2018, 11:14 PM | #1 |
Bench Bleeding Mess
Bench bled my master cylinder, but when I remove the temporary tubes to attach the hard lines to my combination valve, all the brake fluid flows out the ports all over everything. I can't possibly get both ends of the brake lines tightened in time to prevent a big mess. Any suggestions?
I have a setup like this: |
05-17-2018, 12:11 AM | #2 |
Re: Bench Bleeding Mess
are you putting the cap on the master cylinder reservoir? having the cap on makes the leakage slower, it doesnt stop it.
if the cap is on and you have the ports blocked (it came with port blocking plastic caps right?) you dont have to get the lines on without losing any fluid, you just have to get the lines on before the reservoir loses ALL the fluid. so a rag will help.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-17-2018, 01:20 AM | #3 |
Just capping the fitting holes off with the little plastic caps the new master came with seems to work for me.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
05-17-2018, 02:22 AM | #4 |
Post Whore
i do it the way joedoh suggested.....put the lid on and the seal will hold fluid in giving you time to hook up lines before it drains dry....
05-17-2018, 11:22 AM | #5 | |
Brian
05-17-2018, 02:24 PM | #6 |
You can see that to connect the lines, I have two ends to screw in on each port. By the time I get both ends attached and tightened, I've lost virtually everything in the reservoir and now introduced a bunch more air in the system.
Is the any way to connect everything and THEN bleed the MC? Would a Mity-vac unit bleed the entire system including MC? |
05-17-2018, 03:08 PM | #7 | |
you may have a problem with the check valves in your master cylinder, with the cap on and the port open (no plug. hose or line installed) it leaks very slowly on the ones I have done. I have plenty of time to remove the hose fittings, install the plastic plugs, check the level, add if necessary, take it to the truck, install it, remove the plastic plugs one at a time, install the brake lines one at a time, check the level again. if your lines are hard to line up, install the lines before installing the master. dual circuit systems usually have a dam in the reservoir so one side going down doesnt totally affect the other. bench bleeding saves time over normal bleeding but if you have a vacuum bleeder you wont need to bench bleed. sometimes with a new master I will gravity bleed the fronts (just leave the bleeders open with a hose to a pan) and vacuum bleed the rears, which can be a giant pain anyway with an empty system. on this last one I did the bleeder hose to a bottle of brake fluid and pump the brakes trick, no amount of vacuum was pulling that fluid from the master.
05-17-2018, 04:51 PM | #8 | |
The challenge to doing this comes when you have a system with an isolation valve that locks out 1/2 of the brakes if there's a pressure mismatch. Getting the valve to unlock sometimes means waiting overnight for pressure to equalize. FWIW I never seem to have good luck vacuum bleeding. |
05-17-2018, 06:58 PM | #9 |
Bolt master cylinder in place ,make up two short lines install on master put other end in master (where you fill it ) fill with fluid and keep the two lines in fluid at all times. Pump the pedal keep pumping 5 or six times ,then check fluid ,fill if needed . Pump again until all air is gone , Now put your lines on and bleed system. Done one line at a time .
05-17-2018, 07:45 PM | #10 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
05-17-2018, 08:29 PM | #11 |
Get a bench bleeding.kit, they are cheap and you will have almost no spillage. Take the fittings off the mc and screw in the adapters and stick the other end of the hoses back in the fluid and stroke away. It makes the job very easy...
05-17-2018, 09:06 PM | #12 |
I did not have the lid tightened down with the bales, so maybe that will slow the outflow while I attach my hard lines. I'll try again and let you know.
05-22-2018, 06:36 PM | #13 |
Follow up:
I re-bled my MC on the car and this time secured the lid by snapping down the bales while I removed the bench bleed tubes and attached the permanent hard lines, as recommended by astute members of this forum. Only about a teaspoon came out of each port while they were open, which was easy to contain. I had been avoiding closing the bales because they are EXTREMELY hard to snap down, but evidently just setting the lid on the top doesn't provide adequate vacuum to prevent fluid draining out. I've bench bled many systems, but never encountered this before. Evidently I'd always closed the lid before. Thanks for the suggestions gentlemen! Now the next problem: I can't get any fluid to the rear brakes, no matter how much I pump the pedal. Why not? Would a vacuum bleeder pull it through? |
05-22-2018, 08:04 PM | #14 | |
sometimes I cant get fluid to the rear no matter WHAT I do, especially on a totally empty system. what always works for me is to attach a hose to the bleeder and sink it in a bottle of brake fluid, then pump pump pump and after 4-5 pumps bam, fluid is coming out. on those trucks I NEVER get it with a vacuum bleeder, I have spent a half hour before pulling vacuum on it with no luck.
05-22-2018, 08:53 PM | #15 | |
05-22-2018, 11:56 PM | #16 |
Yes. Apparently I may have triggered the pressure differential valve and will have to figure out how to reset it.
05-23-2018, 12:43 AM | #17 |
Post Whore
as I was reading this I was thinking proportioning valve tripped...sounds like you already know it....on some you can reset it with a small screwdriver by sticking it in the end...you can also loosen the front brake line and make it trip by pressing the brake pedal...they make a little tool you can screw in the center to keep it from moving while your bleeding once you get it recentered...
05-23-2018, 02:29 AM | #18 |
Thanks Mongo Greg. I have built many brake systems but this is my first time using the OEM style brass block combo valves, so I didn't know about that trick. I couldn't find the tool locally so I'll order it now.
05-23-2018, 10:37 AM | #19 |
Sometimes it's possible to trick the valve into moving with a shot of air applied to a bleeder. Sometimes letting the vehicle sit overnight is enough to cause it to move off its seat. Either way, if the valve moves the next step is to gravity bleed. Applying pedal pressure will only re-seat the valve and you will end up right back to where you started.
The tool is nice. I've never owned one. |
05-23-2018, 08:11 PM | #20 | |
05-23-2018, 10:00 PM | #21 |
Nice! Good luck.
