05-19-2018, 08:27 PM | #1 |
Rear Disc, prop valve?
Can I just add a generic adjustable prop valve when adding rear disc brakes or should I run a disc/disc prop valve like the link below shows?
https://www.ebay.com/itm/GM-CHEVY-DI...19.m1438.l2649 Also I'd like to replace my driver side front brake line cause it is too long. What was size is the line? I know the prop side is 3/8 - 24, is this the size for the coupling to the flex hose too? |
05-20-2018, 10:32 AM | #2 |
Re: Rear Disc, prop valve?
Can't help on the line size. I used a Wilwood prop valve when I went to an 8.8 with disc out of a Crown Vic. I think you really need to be able to have that adjustment the Wilwood allows.
05-20-2018, 09:25 PM | #3 |
Add me to the list for a Wilwood adjustable. I have one on my truck.
05-20-2018, 10:27 PM | #4 |
Wilwood adjustable it is! I have one in my ‘64 Nova but there is no other prop valve so I wasn’t sure if the disc/drum valve in my C10 would mess it up
Posted via Mobile Device |
