05-26-2018, 06:25 PM | #1 |
I need a narrow tire.
I put a two or three inch to long rear end in my 57 swb. (95 camaro) The tires will rub on the fenders. The tires are 235/75/15 on 15" rally rims that are 8" wide. I am looking for an easy solution and I have two possible solutions.
1. Go to a narrower tire, 215/60/15. I need about 2". 2. Raise the height of the bed to let the tire clear the fender. 3. Or both? Any ideas? |
05-26-2018, 08:32 PM | #2 |
Re: I need a narrow tire.
Rims with less offset would be your best bet. If the rear is disk brake you may run into clearance issues though.
Jacked up with the tires sticking part way out of the opening will really give you that 70's look though. I can't find the photo of mine looking like that in the 70's
05-26-2018, 09:35 PM | #3 |
That was my first thought: go to wheels with positive offset. They will move your tires in, and look more stylish than a jacked-up rear.
But if you want to explore different tire sizes go to TireSize.com for exact dimensions of every tire size: https://tiresize.com/tiresizes/235-75R15.htm . Last edited by MiraclePieCo; 05-26-2018 at 09:53 PM. |
05-26-2018, 11:11 PM | #4 |
(Jacked up with the tires sticking part way out of the opening will really give you that 70's look though) I resemble that remark! My truck is a late 60s/early 70s hotrod. Back when us poor kids didn't have much money and had to rely on a set of used big tires off a Caddy from the junkyard to get that raked look that was so cool back then!
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
05-26-2018, 11:40 PM | #5 |
215/60/15 wouldnt fit an 8 inch wide wheel without a fight, and would look super ridiculous.
I am with miracle, get wheels with 2" less backspace. if you want rallies, just measure your current backspace (straightedge across back of rim, measure from straightedge to wheel mounting surface) and subtract 2. backspace is different on different width wheels too, so a 4" backspace 8" wheel may not fit, but a 4" backspace 6" wheel might. so stick with the same widths or at least try to understand how they are interrelated.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-27-2018, 08:23 AM | #6 |
I failed to mention. My front wheel lug holes are almost all the way to the street side. The rear have a 3-4" set back from the street to the lug holes.
I swapped them to see if two new rims would work. I have the tire just rubbing the fender. Sorry that I do not know the proper terminology. However this is a hot rod, not a show truck. |
05-27-2018, 08:54 AM | #7 |
I just went to the shop and remeasured the distance from the floor to the top of the tire and from the floor to the fender opening
Floor to top of tire 28" Floor to top of fender opening lip 23" Floor to bottom of bed in the rear 20" Floor to bottom of fender at rear 14" I am back to a year or so ago, wider fender would work but not practical. |
05-27-2018, 11:48 AM | #8 | |
the shortest and least painful way to solve your problem is to buy a wheel with 2 inches more backspace. if that looks wonky to you, and it probably will, the second least painful way is to change the rearend. make sure you get one that is only as narrow as you need or you will run into the opposite problem with the tires hitting the bed sides. in fact, maybe measure that distance now so you know how how much narrower you can go. the last option would be to narrow the rear end you have or widen your fenders. a lot of building is getting it "right", not just solving problems. believe me if you solve a problem the fast way you will be able to point it out to anyone that doesnt notice it right away, and there wont be many of those people. with that in mind my advice is to either find a narrower rearend or have yours narrowed exactly as much as it needs. neither is the cheapest option but both will look better than a high positive offset rear wheel or a skinny little tire or even widening the fenders.
05-27-2018, 12:18 PM | #9 |
Post Whore
^^^[in fact, maybe measure that distance now so you know how how much narrower you can go.the last option would be to narrow the rear end you have or widen your fenders. ]
[with that in mind my advice is to either find a narrower rearend or have yours narrowed exactly as much as it needs.] [a lot of building is getting it "right",]^^^ what I was thinking as well
05-27-2018, 12:55 PM | #10 |
i run P235/70R15 on 86 trans am 62" wide rear axle, similar rear axle to yours
first off you are running extreme deep dish wheels with little offset, i believe mine are 4'' offset second you have no tubs to run that wide of a tire, consider mini-tubs in the bedsides truk is on stock springs and stock spring hangers, with the axle flipped on top of the springs your wheels look at least one inch less offset than mine granted i don't have much space between the fender lip and tire, but it never rubs to change tires i have to jack up the frame, remove the lugs and wiggle the tire out from between the fender lip and disk brake it works
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 05-28-2018 at 06:30 PM. |
05-27-2018, 01:01 PM | #11 |
consider mini-tubbing the bed
i used a jigsaw to cut an arched opening in the bedside and used the cutout piece to make the tubs by reusing the cutout it kept the bed profile in the tubs 10 gauge metal 3 inches wide filled in the gap, made for easy welding with no warpage
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-27-2018, 10:38 PM | #12 |
The rally wheels you show in your picture look to be the same as 68-79 vette 15x8. These have the most negative ( toward the outside )offset of any factory rally wheel. Factory 70-75 15 x 7 monte Carlo rally wheels would fit your current tires just fine and give you 2-3 inches toward the inside easy. These wheels are not rare at all, likely to be on craigslist most of the time.
Steve weim55 Colorado Last edited by weim55; 05-27-2018 at 10:46 PM. |
