Old 05-30-2018, 05:55 PM   #1
colyank
Trouble starting 72 pickup
Having trouble starting my 72 Chevy Pickup lately and can’t seem to figure out what the problem is. I had the truck running smoothly about 6 months ago after I had rebuilt the carburetor. About last month it has had lots of trouble starting and it took dumping gas into the carb to be able to start it and then had lots of trouble staying running. Now it won’t even start, I took apart the carb again and made sure everything was good, didn’t make a difference. NNext I’m going to try checking all 8 spark plugs to see if that could be the problem. It kinda sounds like while it trying to start and run, there’s some type of timing issue while cranking on it. Anyone have any idea on what could be wrong?
colyank is offline   Reply With Quote
Old 05-30-2018, 06:03 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Trouble starting 72 pickup
I had an old motor with a similar problem and it turned out that the timing chain was worn so bad that it skipped a tooth. Wasn't a chevy but same could be true for yours. But since you just did carb work, then I would triple check that system including the fuel filter, fuel pump, etc. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 05-30-2018, 09:18 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
In my experience as a mechanic, 99% of the trouble with vehicles of this vintage is electrical. HEI went a long way to correcting that. Check and see if you have spark on cranking. I've seen where the wire on the "R" terminal was corroded or loose and the coil didn't get enough energy to fire the plugs.
It looks like you may have a choke issue, though, if it won't start cold and the spark is good.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 05-31-2018, 08:33 PM   #4
CC69Rat
CC69Rat's Avatar
My thoughts too. I'm a Holley guy .. So, I'm giving you Holley guy direction here. .. If it's electric choke, make sure the choke pulloff is clocked all the way back as far as it will go. You'll see three small screws on the choke pulloff housing. Loosen them about half way out and turn that choke pulloff housing all the way clockwise until it stops. Then turn it back just barely, maybe 1/8 of an inch, then tighten your screws back down.
Bet you a dollar it fires up. Have a flat screwdriver ready because you will likely be adjusting the idle too.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
