Old 05-31-2018, 05:24 AM   #1
_skully
Heater Removal?
Is there a writeup about removing the heater (core, box, hoses, ETC...) from a 67-72 truck? I have seen delete plates discussed at length, but nothing about how to remove everything and what to do/not do. I assume its as simple as removing the components and capping the hoses, but I dont want to assume something that could cause my engine to get cooked.
Apologies if this has been discussed elsewhere, but I could not find quite what I was looking for. Perhaps it is just too simple of a question, but better to ask the experts here before tearing something out that could possibly cause engine damage.
Thanks in advance!
_skully is offline   Reply With Quote
Old 05-31-2018, 07:09 AM   #2
flashed
Re: Heater Removal?
I never used a Delete plate ,used Vintage Air ,but removal is easy and straight forward , just start taking it apart.
flashed is offline   Reply With Quote
Old 05-31-2018, 10:14 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Heater Removal?
Older threads but relevant none the less....
http://67-72chevytrucks.com/vboard/s...d.php?t=600448
http://67-72chevytrucks.com/vboard/s...ad.php?t=69812
LockDoc
Leon
Old 05-31-2018, 01:01 PM   #4
rockyrivermark
Re: Heater Removal?
There is a good YouTube vid on it.
Search c10 heater core
You have to remove pass hood hinge but the process is real easy.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 06-01-2018, 07:43 AM   #5
panhead59
Re: Heater Removal?
One heads up tip is to cut heater hoses off of heater core to remove them. They are most likely stuck or sealed onto the core and if you try to twist them off it usually breaks the heater core.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 06-02-2018, 10:12 PM   #6
_skully
Re: Heater Removal?
Thanks for the replies.
I’m not sure I was clear enough before about my intentions. I’m talking about removing the heater components and tossing them and having a truck without a heater. It’s only an ice cream and cruise night car, so I could shed some weight and make the engine bay look better in the process.
I’m basically asking if it’s as simple as “pull it all out, and don’t put it back on. Then cap off (or bridge with a small piece of hose?) the lines running to the heater core”
Old 06-03-2018, 02:16 AM   #7
SeanB242
SeanB242's Avatar
Re: Heater Removal?
Yes just remove the box inside and out. As far as the hoses I remove the fittings from intake and water pump and put pipe plugs back in. That is on a small block so others may be different but I wouldn’t think so.
SeanB242 is offline   Reply With Quote
