1988-1990's truck steering wheel?
Is the steering wheel a direct replacement in a 1969 C10, is the shaft the same size? I see them in these trucks alot.
![]() Join Date: May 2010
Re: 1988-1990's truck steering wheel?
They fit fine. The outer hub diameter is a bit larger than the steering column.Your horn contact will have to be replaced by a wire.
There are several versions of the 1988-1994 steering wheels to pick from. Mine is a leather wrapped version from a 1994 S10 Blazer LT. Last edited by FirstOwner69; 06-05-2018 at 12:21 PM. |
Thanks, exactly what i wanted to know.
