06-16-2018, 11:05 AM | #1 |
Power Brake Conversion Problem
I added power brakes to my 72 c10. I have a new MC for power brake setup, a factory bracket, pushrod, and booster. I have read that the pedal will be somewhat closer to the floor board with the power setup, so that didn't surprise me (only 1 hole in brake pedal). However, the brakes feel harder than manual. They bled up fine, and I bench bled the MC and i do not have a brake warning light. If I step on the brakes while running, the rpm's die off very noticeably. After shutting off the engine, I can hear hissing for a few seconds. Could a faulty booster be the problems? The brakes seem to work the same with the vacuum line pulled off the booster.
72 Cheyenne Super C10 SWB 2001 Silverado 1500HD Crew 2011 Silverado 2500HD Crew Duramax (Hers) Last edited by rharris; 06-16-2018 at 12:16 PM. |
06-16-2018, 12:48 PM | #2 |
Who Changed This?
Re: Power Brake Conversion Problem
Yup, sounds like a vacuum leak. You should not hear any hissing.
06-16-2018, 01:23 PM | #3 |
Moderator
Vacuum leak.
06-16-2018, 08:31 PM | #4 |
i assume with the engine dying when pushing the brake peddle it would point to the booster. The manifold fitting and vacuum tube are new. I also noticed that when I shift into gear it has a lag time. Guessing that is due to the leaky diaphragm in booster.
72 Cheyenne Super C10 SWB 2001 Silverado 1500HD Crew 2011 Silverado 2500HD Crew Duramax (Hers) |
06-22-2018, 05:58 PM | #5 |
Thanks fellas, new booster came today - works much better. Brakes seem to grab all at once but they work much better. Maybe some adjusting this weekend.
