06-16-2018, 08:36 PM | #1 |
Need help with cam ID/selection...
Took my engine apart to install my new intake - has a torqer 2 going with a Performer RPM and Enginetech cam ES179R (223/223dur @ .050 and .447/.447) but I found a part# on the back of the old cam; E1211P. Looks like its a Elgin, suppose to be 224/234dur @ .050 .466/.487 lift.
So now I'm not sure what to do. Keep the old cam? Install the new one?? Buy a different cam altogether? Thanks. Last edited by Anthony14; 06-16-2018 at 09:26 PM. |
06-16-2018, 10:21 PM | #2 |
Re: Need help with cam ID/selection...
Why are you changing cams? Just curious but your going with a smaller cam, why not stay with the old cam and try the new manifold. I'm guessing this is a 350, what's the compression?
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
06-16-2018, 10:32 PM | #3 | |
I have a sbc350, th350 with longtubes and a Holley 650DP. The rear end was a 2:73 and I'm in the process of putting in 3:42 gears in now. I was upgrading because I wanted more power, more torque. It's a fun truck, light to light. But still do highway driving. SO I thought I was upgrading from a stock cam to a "bolt in" upgrade with a street intake manifold instead of that single plane manifold. Guessing the compression is stock at 8:1 with those 76cc smog heads. All this work part of me wants to buy heads to save myself the trouble of doing the tear down again. |
06-16-2018, 10:40 PM | #4 |
The gear change will be night and day with your truck. You'll think you have another 100hp. I hear you on the heads, if the motors fairly low miles I would do it. You know how it is, you make a little more power then you want to make some more.
06-17-2018, 08:39 AM | #5 |
That Enginetech cam is a 350hp 327 clone. I would keep the Elgin cam if it looks good and get your money back on the other one. Spend it on a converter. A 2000 rpm stall will help immensely along with the gear change.
