Old 06-17-2018, 11:58 PM   #1
barry1982
2003 Sierra 2500HD 4 x 4 Duramax 6 speed
Good Evening Gentlemen,
Is anyone out there running a Duramax with a 6-speed standard?
Mine has been a great truck until suddenly I seem to be having clutch issues.
Truck worked fine with zero symptom's until Friday. Jumped in to drive truck home, and with clutch peddle depressed truck will not go into gear. I stopped engine, and started in gear, and the truck moves with clutch pedal depressed. Drove home using engine RPM to shift. Clutch is not slipping.
Anyone have similar problem? The pedal does feel different then it used to.
Slave cylinder master cylinder has fluid in it. Nothing with the pedal appears to be broken.
Has anyone had similar problem? What did you have to repair?
barry1982 is offline   Reply With Quote
Old 06-21-2018, 11:16 AM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: 2003 Sierra 2500HD 4 x 4 Duramax 6 speed
Sounds like the slave cylinder is done. I would replace it...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-21-2018, 12:23 PM   #3
barry1982
Thanks Joseph..... I'm thinking the same thing from the research I have done. Would you know if a special tool is required to disconnect the supply line from the slave cylinder?
