Old 06-18-2018, 09:29 PM   #1
rsgt
rsgt's Avatar
A little support for my 72 driveshaft support bearing
I have seen where these carrier bearing mounts break off on this style so I added a little support. This is a fernco rubber pipe hub I got at lowes. I cut it at 6 1/2 inches, I should have done 7 1/2. I think I will get another one. The ridges on the side hold it in nice and tight. I sprayed it with WD40 and tapped it in from the transmission side.
rsgt is offline   Reply With Quote
Old 06-18-2018, 09:56 PM   #2
cornerstone
cornerstone's Avatar
Re: A little support for my 72 driveshaft support bearing
Nifty! Let us know if you can feel and additional vibrations or sounds and how it turns out in time. Looks like a great idea to me.
cornerstone is offline   Reply With Quote
Old 06-19-2018, 08:08 PM   #3
bill3rail
bill3rail's Avatar
Not sure that will prevent the metal from breaking however I think having one in the tool box might get you home if the bearing housing does break.
I recently replaced my hanger bearing, not due to the metal breaking, the rubber was worn out and shaft was scraping on the housing.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 06-20-2018, 12:09 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I like it, I like it a lot...I'm wondering if a full radiused piece with a single slit to clear the stem at the top? Zip-tie and it should help dampen and keep the bearing stem located and held in position..?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-20-2018, 04:09 PM   #5
rsgt
rsgt's Avatar
I tried to get more of it in there but couldn't get it to go. I am sure I can get the 7 1/2 inch in which should go half way around. I think it will be plenty.
Old 06-23-2018, 02:35 AM   #6
BCOWANWHEELS
Waste of time
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 06-23-2018, 02:52 AM   #7
Ironangel
Ironangel's Avatar
Originally Posted by BCOWANWHEELS View Post
Waste of time
In your opinion? How can dampening a vibration be a waste of time? Not trying to start a pissing contest but please explain how or why?
"Two Seventy Two's"
02 3/4 ton Express
Old 06-23-2018, 04:56 AM   #8
BCOWANWHEELS
It wont stay in.......... And its not 100 percent contact.
