06-21-2018, 12:31 AM | #1 |
70+ ( Old Skool Club )
Heater Blower Motor Question
We are experiencing a heat wave here and I am enjoying using the factory A/C in my 72 which works fine. My question is when I have the fan on the highest position the noise form the motor is super loud as opposed to the 2/3 lower fan speeds. Is this a normal thing with factory A/C as you can't really have a conversation in the truck when the blower is on high.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-21-2018, 08:13 AM | #2 |
Old member
Re: Heater Blower Motor Question
Mine doesn't. It's pretty quite and that with my hearing aids in.
It's fairly easy to take out though.
06-21-2018, 09:08 AM | #3 |
It is definitely louder, because it is m moving more air. Hard to determine if yours is working correctly without hearing it. Is it rumbling or squealing or just louder from moving significantly more air?
06-21-2018, 09:45 PM | #4 |
Just louder. I'd say its 50% louder than at the speed before.
