06-22-2018, 12:33 PM | #1 |
A Wondering Truck....help
Ok, I have 70, c-10, SB, Toyo tires, lowered w/springs and spindles, 4 new ball joints,good front end alignment.....this thing wonders all over my lane of traffic, its not play in steering, (new close ratio), I have new Belltech shocks coming. Any body have any other ideas? people following me says looks like i been drinking....lol
06-22-2018, 01:10 PM | #2 |
Re: A Wondering Truck....help
Center link on backwards?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-22-2018, 01:19 PM | #3 |
Damn, I wanted to be the hero that magically knew the center link was backwards, but I was too slow!
Happens all the time. If it's really darty it's becasue it needs way more caster, which is screwed up if that link is backwards. If it's not backwards, still sounds like (if nothing is worn or defective) you need more caster. Did you get an alignment spec sheet back when they were done? Usually if its backwards they can't get it in spec.
06-22-2018, 01:58 PM | #4 |
The Older Generation
Also, if you don't have a front sway bar they are a big improvement for handling. The lack of one wouldn't cause what you are seeing though.... LockDoc
06-22-2018, 03:49 PM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Probably just needs a toe in adjustment...I've found that especially after a spindle/spring drop, the toe in needs a little tightening up...I do it myself by scribing a line down the center of the of each tire. You have to jack up each tire, (or both if you jack up both sides from the crossmember) to scribe the line down the center of the full circumference of each tire. Center your steering wheel and lower the truck. Take a measurement between tires, front to front and back to back. The front measurement should read 1/8" to 3/16" of and inch less than the rear.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-22-2018, 04:02 PM | #6 |
Did you get an alignment after you did all that work?
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
06-22-2018, 06:28 PM | #7 |
What is your truck wondering about? I guess you mean wandering. Are all the other parts in the steering system new, or just what you mentioned? Have you looked underneath at all that while someone works the wheel? Was it aligned after the suspension work?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-23-2018 at 07:14 AM. |
06-22-2018, 06:33 PM | #8 |
Scrapper 1
i HOPE WHEN GUYS RE DO THERE FRONT ENDS LIKE UPPER AND LOWER BALL JOINTS THEY DON'T GO THE CHEAP WAY.Me I'm a MOOG guy every thing needs a Zirk fitting so you can grease your upper and lower stuff makes your stuff last a mega long time.It might be a little more But well worth it
06-22-2018, 09:37 PM | #9 |
Should always change the U-bolts that hold the lower control arms. Had one snap on the front of the drivers side lower when I was making a turn towing my camper home from a trip and had the truck dart to the right and almost hit a pole! Was only going about twenty.
68' with no bells or whistles unless I add'em. |
06-22-2018, 11:30 PM | #10 |
x2 on the Moog parts.
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
06-23-2018, 07:13 AM | #11 |
Moog parts are best, good to know you make a good choice, but that has nothing to do with this guy's issue. I doubt his new parts are worn out quite just yet. Any suggestions?
06-23-2018, 07:53 AM | #12 |
06-23-2018, 08:08 AM | #13 | |
06-23-2018, 10:51 AM | #14 |
What size and backspace wheels and tires? I had a bad wandering issue on another vehicle, turns out it didn't like the amount of backspace on the wheels I was running. Wheels stuck out too far. I replaced every joint, bushing, couple alignments and couldn't get rid of it. Just out of curiosity I put he stock wheels/tires back on the front. Problem went away. So I found some rally wheels with a better backspace. No more two handed death grip.
68 K20 Custom Camper/CST Wrecker. 97 GMC K1500 short bed reg cab. |
06-23-2018, 11:35 AM | #15 |
Active Member
Check out this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=400205 It shows a pick of the OP truck with it on backwards and another with it on correct. If the tie rods are coming out the front, it’s backwards.
David Larsen 1970 Chevrolet C-10 |
06-23-2018, 12:59 PM | #16 | |
06-23-2018, 01:00 PM | #17 |
