06-23-2018, 12:57 PM | #1 |
Wood floor question on longbed
Do you place bolts in all holes? I took this apart 10 years ago and vaguely remember the bolts were not in every hole.
Any pics of original wood beds for reference? Thanks! |
06-23-2018, 02:20 PM | #2 |
Re: Wood floor question on longbed
Mine is not original, but i believe that there was a hole or two that were not used in the old bed
06-24-2018, 08:35 AM | #3 |
If you're referring to the Squre cut hole (on both sides) just in front of the wheelwells? I've wondered the same. My bed is unmolested so I would have to assume they were there for the numerous options from the factory. There is no hole drilled in the wood, so there's be ever been a bolt in it. The quirky thing about these trucks is that the "bosses" for every imaginable option, (to include left or right hand drive) are on all original components.
06-24-2018, 09:09 AM | #4 |
Longhorn or longbed? The longhorn has extra bolts and I wound up with two kits!
06-24-2018, 09:57 AM | #5 |
Mine is a 68,C-10 longbed with the optional wood bed and there no extra holes in it.
Mike. |
06-24-2018, 11:18 AM | #6 |
I think I will leave the one bolt out in front of the wheel we'll. I remembered there was at least one not drilled. Before I drill this new piece of wood, I wanted to be sure.
Probably no harm in placing bolts in all holes, but wanted it to be like it was originally. Dave, I may need a couple bolts from your extras |
06-24-2018, 11:41 AM | #7 |
That extra hole in the bed flange may have been for the in-bed spare tire bracket.
Mike. |
06-24-2018, 12:57 PM | #8 |
Mine had one or 2 holes without bolts on each side between the wheel wells and front bed panel that did not have bolts. I don't remember which, but I'm almost positive the two holes immediately in front of the wheel wells had bolts in them. I also put bolts in all holes when I replaced the wood. Just looks better. I ordered more bolts from Mar-K.
