06-24-2018, 12:53 PM | #1 |
Washer Jar questions
hi there all! I have a 1969 Chevy Custom C/10 that didn't have the jar bought one from LMCTruck and I am lost on how to set it up I know the wiring for the motor the black is a ground but not sure about were to attach my red wire. The Picture is the one I bought!
1969 Chevy Custom C/10 Hastings NE |
06-24-2018, 01:04 PM | #2 |
Re: Washer Jar questions
I would run a fused lead off the drivers side terminal block on the radiator core to the pump. Then run the ground side to the cab, thought the switch and to ground under the dash. That would save you some wiring run. Make sure switch is rated for current draw of pump. Otherwise run a relay.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust) |
06-24-2018, 02:12 PM | #3 |
Why not use the stock set up instead of aftermarket ?
06-24-2018, 04:19 PM | #4 |
Here is the wiring diagram that is on this site.
Hope this will help.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
06-24-2018, 10:10 PM | #5 |
I would if it came with it my truck didn't ever had the jar or any of the washer stuff besides the wipers and motor
06-24-2018, 10:44 PM | #6 | |
Look at items 9, 12, 13, 16 Here is the LMC tank on my 70 GMC.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI Last edited by Rufas; 06-24-2018 at 10:45 PM. Reason: Added Quote |
06-24-2018, 10:48 PM | #7 |
What is the part no. of this LMC kit?
You probably just need to run the red wire to a Hot when the key is on power source .
06-25-2018, 12:00 AM | #8 |
Its a Truck Thing......
I wire mine to the original washer plug at the wiper motor. The Wiper/Washer provides the ground circuit when you push the button in. There is a blue and yellow wire at the plug. One is hot with the key on, the other shoots the ground when given the go. Make sure your switch is tight as it gets its own ground that way. I can take a picture if you like. I always ditch the factory pump set up and replace it with the S10 style. Fits great under the hood.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
06-25-2018, 06:26 AM | #9 |
Instructions didn't come with this aftermarket redesign item that never came on these trucks?? They just leave you guessing how to use this adaptation they conjured up that you handed them money for? Ask them.
07-04-2018, 11:41 AM | #10 |
Special-K the washer just cane with the jar and the buttons and hoses that’s all. Think it’s stupid too.
