Old 06-24-2018, 02:12 PM   #1
beaterku
beaterku's Avatar
RideTech Lower Cross Shaft Hole Alignment
So I am trying to button up the front suspension and came across a problem. The lower arms have 2 sets of holes. Instructions say to use the 9-1/2 center holes. While I was measuring, I checked to make sure they are centered on the shaft. Turns out they are not. They are 1/8” off set. The instructions do not mention anything about this. Any ideas? Figured this happens on a Sunday.
Nick
beaterku is offline   Reply With Quote
Old 06-24-2018, 11:19 PM   #2
Ruscal
Re: RideTech Upper Cross Shaft Hole Alignment
I don't know the official answer if there is one. If not I would install it so you get more caster.
Russ
RC
Ruscal is offline   Reply With Quote
Old 06-25-2018, 11:18 AM   #3
beaterku
beaterku's Avatar
Just talked to Ridetech. They said the holes should be offset towards the rear. My understanding is this would reduce the caster, moving the lower control arm back in relation to the upper. This seems backwards of what these trucks like. Don't they like more caster, moving the lower control arm forward in relation to the upper?
EDIT: I'm an idiot and not thinking clearly this Monday morning. Offsetting the holes towards the rear of the car will move the lower arm forward, this giving positive caster which is more gooder. I guess I was trying to think about this too hard.
Old 06-25-2018, 08:40 PM   #4
Ruscal
Pete,
If Ridetech gave instructions I would follow them. The caster angle was designed into your parts. I don't know what caster their design achieves, but my Hotchkis arms have plenty caster and truck seems to like it a lot!
Russ
RC
Old 06-26-2018, 02:18 PM   #5
beaterku
beaterku's Avatar
Originally Posted by Ruscal View Post
Pete,
Russ
I was having a case of the Mondays and was thinking about it way to hard. All is good now!
