Old 06-25-2018, 06:42 PM   #1
jimbuck1050
jimbuck1050's Avatar
VDO gauge problems
I have changed out my stock gauges for a set of VDO classic gauges. Everything looks good. The problem is the Oil Pressure, Water Temp, and Fuel Level all read about half of normal. I have tested the gauges per VDO instructions, they are ok. I have tested the sending units they are good, they are all new. I have tested the ground and even ran a direct ground from the frame to the gauge cluster. I am at a loss as to what is the problem. Help?
jimbuck1050 is offline   Reply With Quote
Old 06-25-2018, 06:43 PM   #2
jimbuck1050
Re: VDO gauge problems
My truck iis 67 SWB Stepside.
Old 06-25-2018, 07:05 PM   #3
demian5
demian5's Avatar
Originally Posted by jimbuck1050 View Post
I have changed out my stock gauges for a set of VDO classic gauges. The problem is the Oil Pressure, Water Temp, and Fuel Level all read about half of normal.
Fricking metric to standard conversion issues...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
