Old 06-27-2018, 11:52 PM   #1
capriceutah
Passenger Door is stuck shut.
Guys and Girls
did search and tried the remedies in the threads I found
I picked up a 64 c10 at the start of this month and I have been collecting parts for it. I want to start breaking down the front end for the 72 crossmember I have but I cannot get the door to open. I have pulled the door panel and spray WD-40 and pb blaster on the latch inside the door . I've tried prying up on the door ,pulling hard and I can't get it open.
Do you guys have anything other ideas?
Thanks in advance!
Chris
capriceutah is offline   Reply With Quote
Old 06-28-2018, 02:16 PM   #2
61K10
61K10's Avatar
Re: Passenger Door is stuck shut.
I guess the door is not stuck in the locked position. What does the linkage do when moving the inside door handle? How about a big kick with your boot.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-28-2018, 05:04 PM   #3
nsb29
nsb29's Avatar
You might try loosening the hinges
nsb29 is offline   Reply With Quote
Old 06-28-2018, 05:11 PM   #4
rsavage
rsavage's Avatar
If both inside and outside handles won't open it, pull up and push down on the door lock many times and snap it to the top on the last one. My son had the same problem recently on the 65 GTO I gave him and a guy on the Pontiac forums told me (him) to do this. It worked!
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 06-28-2018, 07:19 PM   #5
jayoldschool
Moderator
I pulled the seat belts from a mid 60s car at a yard. Needed to get the pass door open to get the outer belt bolt. Had someone push on the door release outside, and I laid on my back on the seat and kicked the door as hard as I could from the inside. Pop, door opened.
jayoldschool is offline   Reply With Quote
Old 06-29-2018, 12:04 AM   #6
capriceutah
Three kicks for the inside and it popped open.. You guys are the best!
Thanks,
Chris
Old 06-29-2018, 08:56 PM   #7
andyh1956
My 66 sticks after sitting. I use a plastic wedge from a body trim kit to pry it open.
andyh1956 is offline   Reply With Quote
Old 06-29-2018, 09:37 PM   #8
jayoldschool
Moderator
Glad my trick worked! Wouldn't suggest it for a show car, but sometimes... brute force is the answer.
Old 06-30-2018, 08:16 PM   #9
jdl71
jdl71's Avatar
^^^^This
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 12-25-2023, 08:06 PM   #10
Rustycrusty66
I just bought this 64. Both doors are stuck shut. All the windows are up, and the side wings are latched. Tried raising up on the bottom corner while pushing the button and pulling no luck. Dont really want to tear up the door but dont know what to do
Rustycrusty66 is offline   Reply With Quote
Old 12-26-2023, 12:22 AM   #11
SOON2BLAZE
SOON2BLAZE's Avatar
Rustycrusty, I'd pull the back window (good excuse for a new seal) and crawl in there.
SOON2BLAZE is offline   Reply With Quote
Old 12-26-2023, 11:06 AM   #12
cwcarpenter98
cwcarpenter98's Avatar
If it's the latch stuck, maybe some penetrating oil of your flavor will help loosen things up. If you can hear the latch release, then my guess is that either the hinge pins are frozen up or it's just the rubber door seal acting like glue. Some penetrating oil will help on the hinges. If it's the door seals, just yank on it till the seal releases
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-01-2024, 12:38 AM   #13
85gmc1500
First of all glad to be here. I'm kinda wondering if anyone knows where I could find both doors for my 63 c10?
85gmc1500 is offline   Reply With Quote
Old 01-01-2024, 01:03 PM   #14
Getter-Done
Getter-Done's Avatar
Welcome to the Forum.
You can keep an eye out for a set in this part of the Board.
Link to 60-66 parts: https://67-72chevytrucks.com/vboard/...isplay.php?f=7
If you choose to you can become a Subscribing member for $15/$25 and post a Want-to-Buy add here.
Link: https://67-72chevytrucks.com/vboard/...splay.php?f=81
Good Luck in your search.
I am sure you have tried your local pull a parts and swap meets.
84 Chevy K-20
