Old 07-01-2018, 12:04 AM   #1
BleedRedandGold
Questions on axel swap
Picked up a 76 chevy 4x4 shortbed the other day and it has some money into the suspension. My question is can I swap it out with a 71 blazers axel and suspension?
Any input would be great, thanks.
BleedRedandGold is offline   Reply With Quote
Old 07-01-2018, 03:11 PM   #2
Lieferson
Lieferson's Avatar
Re: Questions on axel swap
not sure on the leaf springs, but the front axle should bolt right in, rear you will probably have to move the spring perches
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 07-02-2018, 08:43 AM   #3
Mike C
Mike C's Avatar
Front axle is a direct replacement. Rear axle requires relocating both the spring perches and the shock mounts. Rear springs should be 52” on a short square body and are direct replacements. Some squares had 56” springs but I don’t think 1/2 ton trucks did, but never say never.
The front springs are not interchangeable. They are too long for a 69-72.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
