Old 07-02-2018, 09:14 AM   #1
Wgesnerjr
Wgesnerjr's Avatar
Seat belts
I have a single cab bench seat that sits 3 across. Can someone verify how the double seat belt buckles in the middle are sewn in? I had my seat belts re-webbed and my buckle buttons face away from each other. Seems like when you sit in the truck with the belts on and someone in the middle, the buttons are toward our bodies instead of away. Shouldn't the be facing each other so when buckled, the button is away from our hips?
Before I take them back to the upholstery shop. I wanted to make sure they are wrong.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-03-2018, 12:11 AM   #2
BIGglaSS
BIGglaSS's Avatar
Re: Seat belts
I just looked at my factory belts. They are not back to back like yours. They are both with buttons facing up.
BIGglaSS is offline   Reply With Quote
Old 07-03-2018, 11:59 PM   #3
Pontiac1976
Pontiac1976's Avatar
Re: Seat belts
BIGglaSS
Yes that right.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-05-2018, 06:11 PM   #4
Wgesnerjr
Wgesnerjr's Avatar
Re: Seat belts
So I took the buckles back to the upholstery shop today and they were resewn correctly. Buttons are now facing each other and they should work without having to cross.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 07-05-2018, 07:37 PM   #5
Wgesnerjr
Wgesnerjr's Avatar
Re: Seat belts
So, next question. Thinking about the center seat belt. Does the double buckle go on the left and the belt go on the right, or vice-versa?
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 07-05-2018, 07:46 PM   #6
Wgesnerjr
Wgesnerjr's Avatar
Re: Seat belts
Which way?
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 07-05-2018, 08:04 PM   #7
Wgesnerjr
Wgesnerjr's Avatar
Re: Seat belts
Nevermind. Double buckle on left, belt on right.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 07-06-2018, 08:49 AM   #8
TKCR
TKCR's Avatar
Re: Seat belts
Looking good!!
