Old 07-12-2018, 12:17 AM   #1
cgster
Stepside tail lights
I'm fixing to buy a 67 stepside. Most 67-72 trucks I have seen have 2 lights on each side in the back (a red and a clear). This truck has just a red light. Did all 67-72 stepside trucks come with the 2 lights? How hard to convert back to the 2 lights instead of 1? Do the light holders weld on or bolt on? Thanks
cgster is offline   Reply With Quote
Old 07-12-2018, 12:34 AM   #2
3757chevy
3757chevy's Avatar
Re: Stepside tail lights
any pictures of what you have?,this the stock lights on my '67.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 07-12-2018, 01:08 AM   #3
cgster
Pic
Old 07-12-2018, 07:23 AM   #4
They bolt on by a flat bracket. Both tail lamps and reverse lamps mount separately. What you have now are trailer lights. All parts are offered in reproduction or you can try to find used originals on the parts board.
Old 07-12-2018, 07:29 AM   #5
dave6672
dave6672's Avatar
The light setup on the blue truck is correct.
The square lights aren't original, the round tail lights and reverse lights must have been removed at some point and replaced with what look like square trailer lights to me. The brackets that hold the original round lights bolt on.
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
dave6672 is offline   Reply With Quote
Old 07-12-2018, 07:31 AM   #6
dave6672
dave6672's Avatar
Special K and I must have been typing at the same time (although he was a little faster)!
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
Old 07-12-2018, 03:27 PM   #7
RenoKeene
Florida Edition
RenoKeene's Avatar
Factory brackets bolt to the bed. Readily available on the parts forum.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 07-12-2018, 03:47 PM   #8
68Stepbed
68Stepbed's Avatar
Who needs reverse lights?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-13-2018, 08:59 AM   #9
68panelman
68panelman's Avatar
Pretty sure all states require reverse lights by now, mandated federally in 68.
Here's my 67's rear cheek
68panelman is offline   Reply With Quote
Old 07-13-2018, 11:07 AM   #10
truckman72
truckman72's Avatar
I'm with 68stepbed, who needs reverse! I just have a set of 55's on mine
Roman Catholic Seminarian for the Archdiocese of Kansas City in Kansas
1969 Chevy Stepside
http://www.67-72chevytrucks.com/vboa...d.php?t=392738
truckman72 is offline   Reply With Quote
Old 07-13-2018, 03:18 PM   #11
palallin
Not quite true: MO, at least, doesn't care at all.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 07-13-2018, 10:35 PM   #12
68Stepbed
68Stepbed's Avatar
If there's yearly inspections, then probably. TN doesn't require inspections.
By the way, I like the chain covers. Did you buy those somewhere, or have them made?
Matt
Old 07-14-2018, 01:24 AM   #13
3757chevy
3757chevy's Avatar
I like to backup my driveway, which is about 125' and I come home in the dark alot. I need my lights.
MIKE
Old 07-14-2018, 08:45 AM   #14
68panelman
68panelman's Avatar
I found the covers on a thread here on the forum,
Don't have his info, but he's in Johnstown, NY
Try doing a search on the forum
Old 07-15-2018, 01:41 PM   #15
3757chevy
3757chevy's Avatar
Found 'em http://67-72chevytrucks.com/vboard/s...d.php?t=637480
MIKE
