Old 07-12-2018, 12:57 PM   #1
SonomaComa
1/2 and 3/4 ton control arms the same?
I have a 1969 Chevy C-20 and a 1970 GMC C2500.
I see a lot of aftermarket suspension parts for 1/2 ton trucks mainly the upper and lower Control Arms. I do not see ANY for 3/4 ton trucks. Are they the same? Maybe just the ball joint taper is different? I don't know....
SonomaComa is offline   Reply With Quote
Old 07-12-2018, 02:44 PM   #2
AZ 67 C10
AZ 67 C10's Avatar
Re: 1/2 and 3/4 ton control arms the same?
In 71 they changed the ball joint taper size to a larger size. Other than that they are the same I believe.
AZ 67 C10 is offline   Reply With Quote
Old 07-13-2018, 09:27 AM   #3
Bentbolt
I know my 65 c20 wouldn't take 86 c10 lower arms. the c20 had larger center to center bolt locations then the c10. but the top would bolt right up.
Bentbolt is offline   Reply With Quote
