Old 07-14-2018, 10:13 PM   #1
Big Blue
Big Blue's Avatar
Bushing bolts?
I am trying to install rear cab mounts. A little history first. The cab is sitting on a blazer frame, it is an 1987 cab, but I made a support bracket to support the rear cab. I ordered a set of mounts for a 73-80 2 wd 1/2 ton. Since I made the
bracket support I thought that the size of those mounts would work out ok. Here is the problem, the bolts that came with the mounts do not thread up into the holes. Are the bolts different? Do I need to get bolts for an 87 cab? I know that the threads might be dirty up inside but I don't want to force them either.
Thanks, any more information needed let me know.
John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 07-15-2018, 02:01 PM   #2
Big Blue
Big Blue's Avatar
Re: Bushing bolts?
Never mind folks, I figured it out. I just put the bolt in and use a 3/4 ratchet wrench and took it up with very little resistant.
John
Big Blue ( John )
