Old 07-17-2018, 09:00 PM   #1
NJM73
NJM73's Avatar
Tall deck 427 496 572 vortec 8100 guys, need help with headers
Done quite a bit of searching thru here and have tried the few good suggestions I found without any luck. I have test fit without success sanderson bb8, and hooker 2463 headers. Currently have a butchered set of hedman 68610 chevelle headers that I want to replace.
Truck info, 4wd, currently has a tall deck 427, pushed 2" forward from where the factory 350 was, also had a hydraulic slave cylinder. I am getting ready to swap in a vortec 8100, the blocks are the same dimensions, including additional head height. Using the 427 for mock up so I can have the exhaust ready (o2sensors positioned amd welded in)
Looking for a set of headers that will fit better than what i have. I am going to try shaving an eighth inch off he frame rails soon to see if it will help at all (frame will get boxed while motor is out). I dont want to dent up either set i have yet until i can see if anyone has a similar setup (can still return both sanderson amd hooker)
'71 chevy suburban -all purpose rig- in progress
'93 cherokee -dd- mild wheeler
'65 chevy c30 c&c 12' flatbed -farm truck - future tow rig
NJM73 is offline   Reply With Quote
Old 07-18-2018, 01:41 AM   #2
junksaver
Re: Tall deck 427 496 572 vortec 8100 guys, need help with headers
You may want to post this question in the 4x4 section. Member DirtyLarry post up in that section and he is into 8100 swaps. Here is a link to one of his threads.
http://67-72chevytrucks.com/vboard/s...d.php?t=492583
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 07-18-2018, 04:49 AM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
You know that the Tall deck is not a HP motor its a low end grunt motor.Now if you want to clime a skyscraper That engine with a PTO with a winch will get you in and out of trouble
stsalvage is offline   Reply With Quote
Old 07-18-2018, 10:51 AM   #4
demian5
demian5's Avatar
Agree - I bought a 73 3/4 burb once without a motor (was originally a 454 truck), but got a sweet deal on a running, propane powered 366 complete with the double t-stats. Ran it on gas and it would pull anything.
Later on I traded it for a 454, and after that I learned that the 366 had a forged 427 crank. I think that's why the guy wanted it. We were both happy in the end.
For headers, I just ran some ceramic coated hookers off the shelf for my truck.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 07-19-2018, 10:34 AM   #5
57taskforce
All about them K’s
57taskforce's Avatar
Can’t help with the headers but In a 4x4 you’ll love the 8.1. I’ve had two of them and currently still have one of them. Best gas truck motor ever built in my opinion. Torque for miles down low and I can still get 12-14 mpg on the highway in the suburban if I can keep my foot out of it. I had a 05 Silverado 8.1/Allison that I had planned to run in my 57 but life gets in the way and I had to sell the 05 earlier this year. I’m in to see progress on this one.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
