Old 07-19-2018, 10:32 AM   #1
choctawchevyclassics
choctawchevyclassics's Avatar
67 CST 2WD 6 lug to 5 lug rear diff conversion
Just purchased a 67 CST. I already have a 71 front K-member to convert to 5 lug disc. Wanting to determine the most cost effective way to change the original 12 bolt rear to 5 lug. Is drilling the flanges to 5 lug and filling holes a bad idea?
I have a set of new 5 lug drums for a 71 and was also wondering if those will fit my 67 12 bolt rear brakes. The brakes are the same part number and size 11" X 2".
choctawchevyclassics is offline   Reply With Quote
Old 07-19-2018, 10:47 AM   #2
68Gold/white
Re: 67 CST 2WD 6 lug to 5 lug rear diff conversion
Yes, those drums will work.
Call Moser, they did have a deal on "C" clip axles, $260.00/pair. It's been a while since I've seen that advertised price. My buddie's son ordered a set for his 67 C10 (he lives in Seminole...), few years back, also converting to 5 lug. Not sure if it cast any extra to do the 5 lug 67 deal, but it couldn't be much. Have them install the studs also.
Get some new axle bearins and seals also...Hardest (and sloppiest..)part will be getting old axles out, and newbies in.
Not knowng what shape your old shoes are in, may need to replace them...if so, gat all new hardware and wheel cylinders, this stuff is NOT expensive...
68Gold/white is online now   Reply With Quote
Old 07-19-2018, 10:57 AM   #3
Yes on all the bearings, seals, and brake stuff. Already on hand and ready to install at some point. Just wasn't sure about the drum. I figured they would work, but ya never know until you try or ask. Thanks for the info...
Old 07-20-2018, 10:53 AM   #4
bubbasimms
http://67-72chevytrucks.com/vboard/s...d.php?t=757144
Check this out
bubbasimms is offline   Reply With Quote
Old 07-21-2018, 12:26 AM   #5
Robznob11
Robznob11's Avatar
Fwiw....when I did mine years ago I got moser axles with the car bolt pattern. The 11x2 car drums will work as well. Just have to open up the holes a bit caus they were made for 7/16 studs...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 07-21-2018, 07:35 PM   #6
Mike C
Mike C's Avatar
The Yukon axles, seals, studs from Jegs are a deal. Drums are in the picture but not included. Rockauto can fix you for those.
$160.46
https://www.jegs.com/i/Yukon-Gear/80...RCK-2/10002/-1
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
