Old 07-20-2018, 11:09 AM   #1
Rabid Anti-Dentite
Post Your Wheel and Tire Combo
I have been looking around this forum for a while and there are so many great trucks, with so many different wheel are tire combos, so I thought it would be nice to have a thread to contain it all.
Can you please provide a picture of your truck, what wheel/tire combo you are running, and a brief overview of ride height and/or suspension set up. I figure this could give a lot of us new builders an idea of what we are looking for.
Rabid Anti-Dentite is offline   Reply With Quote
Old 07-20-2018, 03:26 PM   #2
oldman3
oldman3's Avatar
Re: Post Your Wheel and Tire Combo
I guess I'll be first.
16X7 TT2's with 4" backspace, 215/60/16 tires with MII front suspension, 2" drop spindles with coil overs, disc brakes, have 4-1/2" ground clearance at front crossmember.
17X8 TT2's with 3-1/2" backspace, 235/55/17 tires with Nova rear axle on leaf springs.
Here's a pic...Jim
oldman3 is offline   Reply With Quote
Old 07-20-2018, 05:21 PM   #3
MARTINSR
MARTINSR's Avatar
This is a great idea for a thread, and to throw in the suspension and details like Jim did, this could be very valuable info!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 07-20-2018, 05:21 PM   #4
bosco
bosco's Avatar
Went with smoothies. 16x8 235/60-16 all around. Mustang II IFS and stock in the rear.
bosco is offline   Reply With Quote
Old 07-20-2018, 05:22 PM   #5
MARTINSR
MARTINSR's Avatar
Here's a pic...Jim
Jim, what rear springs? Do you have lowering blocks? It doesn't look like it but I have to ask. That truck has the perfect stance if you ask me, exactly what I am after.
Brian
1948 Chevy pickup
Old 07-20-2018, 07:35 PM   #6
RDrancher
RDrancher's Avatar
Nice classic look!
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 07-20-2018, 11:19 PM   #7
oldman3
oldman3's Avatar
Brian
Brian, thanks for the compliment. My rear springs are the stock rear springs from my 1994 S-10 blazer. I put 3" lower springs on my blazer and used the old springs on my truck. Since these are wider that the stock truck springs, I had to change the front and rear hangers. Truck rides nice. I know there are several vendor that sell complete kit to change to the wider springs, which require you to cut the old rivets from hanges and bolt in the new hangers. Oh, and I'm running a 2" lowering block...Jim
Old 07-21-2018, 12:10 PM   #8
MARTINSR
MARTINSR's Avatar
Thank you! That is the kind of info I am after, thanks!
Brian
1948 Chevy pickup
Old 07-21-2018, 02:45 PM   #9
bosco
bosco's Avatar
Originally Posted by RDrancher View Post
Nice classic look!
Thanks. I just love the way these trucks drive. Fun running around back roads.
Old 07-21-2018, 09:43 PM   #10
my56chevytruck
my56chevytruck's Avatar
I have recently changed out the wheels and tires on mine.
Fronts are 215/70-15's 4.25" backspacing
Rears are 255/60/15's 4.25" backspacing
all suspension is 2nd gen Camaro, 10" diff. Front suspension I put on 2" lowering spindles, rear has 4 leafs/side with 1" lowering blocks. Also running a Gen VI big block for power. A Big block vs a small block will affect your stance.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 07-22-2018, 05:11 PM   #11
Jesse Z
What are these "wheels" you speak of? Are they something like rims?
Signed, Every Car Enthusiast In The World Under 40 Years Old
Jesse Z is offline   Reply With Quote
Old 07-22-2018, 05:23 PM   #12
MiraclePieCo
MiraclePieCo's Avatar
I stuck with a 15" tire and wheel combo: 205-70 on 7's front, 225-70 on 8's rear. Why? Because simplicity, practicality and economy are the goal of this build. As soon as you jump up to the performance tire and wheel sizes the cost increases exponentially. Yeah, it might look more trendy with "conestoga" wheels, but the cost just ain't worth it, and I'm not into wowing a bunch of Millennials.
Simple, cheap, readily available:
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 07-22-2018, 05:26 PM   #13
mr48chev
mr48chev's Avatar
195-60 14 on 7 inch rims on the front 255 -60 15 on 15x8 rims on the back. That is the setup I ran for years. wheels are Enkie 32. Pretty well obsolete now.
This go around it is getting 225 15 white walls on 7 inch wheels with hubcaps. Whole different look getting away from the street rod look.
My ongoing truck projects:
Old 07-23-2018, 08:11 AM   #14
Rabid Anti-Dentite
Thank you all for the posts so far, some great info here.
Old 07-23-2018, 04:22 PM   #15
Russell Ashley
Russell Ashley's Avatar
Here's my truck just as it came out of the paint booth at my son's shop. Some assembly required obviously, but shows the stance. It has a Scott's front suspension and TCI rear leaf spring lowering kit. Tires are 235/75/15 on eight inch Corvette rally wheels. This tire and wheel combo is probably a little to old fashioned for some but I like it.
Russell Ashley is offline   Reply With Quote
Old 07-23-2018, 06:16 PM   #16
MARTINSR
MARTINSR's Avatar
I think it's awesome Russell, all I can add is to DRIVE IT! Drive the frigging wheels of it with a smile on your face.
Brian
1948 Chevy pickup
Old 07-23-2018, 06:29 PM   #17
RDrancher
RDrancher's Avatar
Old fashion style and class. I like it.
Old 07-23-2018, 06:56 PM   #18
robertsjm711
robertsjm711's Avatar
16 x 8 with 5" backspacing/+13mm offset (https://www.summitracing.com/parts/brw-997683450)
S10 frame, stock spindles with 2.5" spacers in front
Homemade body mounts
Mid 60's 12 bolt passenger rear stock width
Venezia Crusade SXT 225/60 R16
https://www.youtube.com/watch?v=61BLek1f5Fk
It was said that if you cut off one hydra head, two more grow back.
-Lernaean Hydra
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=743246
robertsjm711 is offline   Reply With Quote
Old 07-23-2018, 08:47 PM   #19
Volfandt
These are what came on it when I traded for it.
Fronts: 215 60R14 Cooper Cobra's on Crager's
Rears: 225 70R14 Cooper Cobra's on Crager's
Thinking on swapping the fronts for taller 225 70R14's to improve the ride.
Volfandt is offline   Reply With Quote
Old 07-24-2018, 07:09 AM   #20
Rabid Anti-Dentite
So question on the backspacing...a lot of the wheels I see are 4.5" backspaced, with the S10 swappers running the 2" spacers. Did you have to run the 2.5" spacers due to the 5" backspace? I have been looking at some wheels with a 6" backspace (20" Dodge Ram Spare Wheels), but I can find anything greater than a 1.5" spacer with the bolt pattern I would need.
Old 07-24-2018, 01:44 PM   #21
ngw91
The day we brought it home (1 year ago)
ngw91 is offline   Reply With Quote
Old 07-24-2018, 10:16 PM   #22
my56chevytruck
wheels or rims are the same thing
1940 Ford Dlx Coupe
1969 Mach1
Old 07-26-2018, 01:56 AM   #23
Jesse Z
Maybe to Gen-Xers and below.
And don't get me started on "stall converters!"
Old 07-26-2018, 10:18 AM   #24
jweb
jweb's Avatar
I'm not sure how your comments are helping anyone on this post. Correcting people or insulting their age isn't what this forum is about. I have learned a lot from all of the "old" guys on here.
Maybe just post your wheel/ tire combo or move on. I'm 40 so I guess I can call them wheels.
Here's mine:
Wheels: 20x8.5
Tires: 245/35/20
Front suspension: Mustang II w/ QA1 coilovers
Rear Suspension: Trailing arms with QA1 coilovers and Ford 8.8 axle
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 07-26-2018, 09:58 PM   #25
Black_Sheep
Black_Sheep's Avatar
235/70R15 on 15x7's
Black_Sheep is offline   Reply With Quote
