07-21-2018, 12:52 AM | #1 |
6 lug on c10 Chevy.
I have a '69 long bed Custom c10, not sure what engine it had, only that it was a v8 with a manual transmission, this was not a 4x4, just 2 wheel drive.
Why is it that some c10's have 5 lug and some 6 lugs? Is the 6 lug a more heavy duty style of a c10 sort of what GM did in the 70's when they made the Big 10? My other question is: Can my '72 disc brake spindles accept a 6 lug rotor? I was hoping to use the '69, 6 lug rear end in my '72 which has a blown rear end. Thanks for any help. |
07-22-2018, 12:06 PM | #2 |
Re: 6 lug on c10 Chevy.
Do you have a picture of the SPID? That will tell you what engine the truck came with.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
07-22-2018, 12:56 PM | #3 |
I believe all C 10 had 6 lug thru '70. With the 71-72 they were 5 lug w disc brakes.
07-22-2018, 08:55 PM | #4 |
Thank you, that seems to make a bit of sense.
07-22-2018, 09:15 PM | #5 |
35 is right.
from 1960 (at least) through the 1970 model year, the C-10s were six lug, with drum brakes. 1971-72 were five lug with disc brakes on the front |
07-23-2018, 12:35 AM | #6 |
Scrapper 1
Not to be mean to all people.But there are a lot more stupid People in this world now days.But a friend of mine told me GM has not been Fair about saying what is 1/2 ton to 3/4 ton.Now from the war time GM Was mostly 6 lug from 1940-1970.Then 1971-1998 they went back to the 6 lug.Now I know that GM wor what ever reason why they went from the C10 to the c1500 an 2500 3500 trucks.
But Its common knowledge that 8 lugs means C20 or C2500 there 3/4 ton trucks or up to 2 ton trucks. One more easy way to tell if you have a 1/2 ton from a 3/4 ton from 1950--1970.You have to undo 8 small bolts to remove the rear Drum on a 3/4 ton 8 lug truck 1971-72 used Dana's where the drum slides off |
07-23-2018, 01:46 AM | #7 | ||
07-23-2018, 02:15 AM | #8 |
Cantankerous Geezer
GM went back to 6 lugs because the trucks were getting heavier and needed the extra lug for the increased loads.
Fred There is no such thing as too much cam...just not enough engine. |
07-23-2018, 06:43 AM | #9 |
You must be one of the stupid people.
For what it's worth, so am I, apparently. I think he meant from 71-98 GM went to 5 lug, not 6. Except 4x4s. Or 3/4 ton+.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
07-23-2018, 09:46 AM | #10 |
Thanks for any help.[/QUOTE] I am not sure on this. Aftermarket companies make 6 lug rotors to keep the swap easier, without having to change the rear brakes. One thing to keep in mind is that your original 6 lug wheels may NOT bolt up to the 6 lug disc brake setup, because of possible brake caliper interference... You would need to call companies offering the 6 lug disc brake conversions and ask... |
07-23-2018, 05:13 PM | #11 |
I converted my 68 to disk brakes many years ago and stayed with the 6 lug. Sometimes I regret it because there are so many more wheels to choose from regarding the 5 lug. I liked my wheels at the time and didn't want to swap the axles in the rear.
I do know the aftermarket 6 lug disks are expensive. And I am not sure they can be used on the factory setup ?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
07-23-2018, 09:35 PM | #12 |
Aftermarket 6-lug rotors are not that expensive, unless you go with drilled and slotted, or big brake setups. Rock auto has 12” rotors for under $100 each.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
07-23-2018, 09:53 PM | #13 |
You're not alone. Only thing I can think of is perhaps a very well hidden reference to the 6 lug 3/4 tons in the early GMT400 years that tend to muddy the waters in a 1/2 vs 3/4 lug count discussion. Or perhaps (and more likely), I have no idea.
07-24-2018, 11:18 AM | #14 |
And all this pertaining to the OP's quandary, right?
All in fun
07-24-2018, 11:28 AM | #15 |
I think "Classic Performance Upgraded Disc Conversion Rotors CP4R-6" will work if the original 72 rotors were 1.25" thick. If not you will need spindles from a heavy half square body.
1969 Chev C/10 1972 GMC K2500 Custom |
07-24-2018, 03:15 PM | #16 | |
67-72 parts collector,…
So are all the disc brake conversion spindles made for 60-62 and 63-70 c10’s
07-24-2018, 07:02 PM | #17 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-24-2018, 09:17 PM | #18 | |
