Old 07-23-2018, 07:53 PM   #1
rsmarr1982
rsmarr1982's Avatar
Exhaust manifolds
I found some 64 c10 v8 manifolds , will they work on a 69? On parts websites they show 69-72 as being the same what about 68 and earlier?
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 07-23-2018, 07:59 PM   #2
Re: Exhaust manifolds
The early small block exhaust manifolds had mounts cast into the front to mount alternator and A/C with no provision on the head for later mounts.
Old 07-23-2018, 08:12 PM   #3
rsmarr1982
rsmarr1982's Avatar
Oh ok that makes sense. On a side note my k20 has the manifolds dump straight down and my 70 2wd I had they angle back a little. Is this the same for 68 and earlier including 60-66?
Old 07-24-2018, 07:16 AM   #4
Yes on all 67-72s and pretty sure on earlier trucks. People cut and grind those mounting bosses off of the early manifolds for use with newer heads/later alternator brackets. '68 trucks had the new style heads and exhaust manifolds. That type of exhaust manifold went out with the 283 in '67.
