Throttle Cable bracket
My 72 Blazer with a manual 4 speed, had been fitted with an Edelbrock Intake and an Edelbrock 4bbl carb by the previous owner and ran fine until the engine needed rebuilding... Somewhere along the way, the bracket for the throttle cable came up missing. Now my mechanic (not the rebuilder) has the engine in but is at a loss to find a bracket to secure the throttle cable to the engine.
I would think that there are adaptable brackets that should work but one would think a mechanic would be able to figure that out. It's been a month with no luck and my blazer is still sitting in the shop. I've suggested he replace the throttle cable or any thing else that might work Any ideas that would help me out? I'd appreciate any input to get it on the road before winter hits. |
![]() Join Date: May 2011
Re: Throttle Cable bracket
Did they reuse the stock throttle cable? Pictures of what you have would probably be a big help.
![]() Join Date: Jan 2001
Summit and Jegs both sell the correct bracket:
https://www.summitracing.com/parts/edl-8036 https://www.jegs.com/i/Edelbrock/350/8036/10002/-1 And if your mechanic is this good at finding solutions to simple problems, you might want to look around for another mechanic. Just sayin'...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
It does have the original throttle cable... but I don't have any photos handy. The Blazer is miles from here right now. I will check out Jegs and Summit.. Thanks.
After sending my mechanic the web sites I was given, I called my mechanic. They never checked their emails and he has put a bracket on and is said to be almost finished.
He's a good mechanic but communication skills isn't one of his strong suits... |
