07-24-2018, 09:46 AM | #1 |
Master Cylinder upgrade
I am looking to go with a Wilwood master cylinder for manual brake upgrade on my 72 2wd 1/2 ton, I talked to Wilwood and they need some info I dont have because my truck is 2 hrs away and cant check myself. The brakes are disc/drum and all stock. Does anyone know what the caliper piston size would be, rear wheel cylinder size and brake pedal ratio? Or has anyone done this and have a part # to go by?
07-24-2018, 11:44 AM | #2 |
Re: Master Cylinder upgrade
Id just go with an early 70s corvette manual master cylinder and use your existing combo valve.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
07-25-2018, 11:09 PM | #3 |
Cant beat stock in any way unless you just want to spend alot for purdy looks
I BELIEVE IN JOHN 3:16 |
07-30-2018, 06:53 PM | #4 |
actually a corvette might not work , I think it has something to do with it being a dual disk set up in vettes while his is a stock disc/ drum st up.
Pontiac in the early 70's made a master cylinder for firebirds that was a disc/ drum MC set up for standard brakes. I have used the 72 firebird as the reference when ordering them in the past. nice thing is that many of the various brake lines are repro'd too so visually speaking it can be made to look very clean and simple install its a common enough MC because its often the mc of choice for conversions too. |
07-31-2018, 02:11 PM | #5 |
Is there something wrong with the stock MC in this application?
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
07-31-2018, 03:09 PM | #6 |
I don't have the caliper size and rear wheel cylinder diameter in front of me, but I have the following:
Stock MC part numbers: Delco - 5469574 Bendix - 6264985 MC bore diameter - 1.125 in Pedal ratio - 5.9:1 K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-31-2018, 05:16 PM | #7 |
Caliper piston diameter is 2.94 inches; rear wheel cylinder diameter is 1 inch.
K
07-31-2018, 08:50 PM | #8 |
I put a wilwood master with their front discs on my 70. Ignore everyone saying "whats wrong with stock?" I have no power assist on mine and they feel fantastic. Great upgrade. Much better feel and performance over the 50 year old factory parts.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
08-01-2018, 08:56 AM | #9 | |
