07-24-2018, 04:27 PM | #1 |
Master cylinder replace or paint?
So I'm dropping a new engine into this beast in a couple of weeks and will be working on cleaning up the wiring, AC and painting the compartment. I would like a shiny master cylinder too, but not sure if I should buy a new one, or if painting them is a decent idea. Appreciate the advice!
also, does anyone know where I can get a new Vehicle Emission Control Info sticker for the wheel well? |
07-24-2018, 04:32 PM | #2 |
Re: Master cylinder replace or paint?
Eastwood makes a paint for master cylinders that approximates the original finish, and it holds up well with little deterioration.
07-24-2018, 04:37 PM | #3 |
I've sprayed them with cast iron or rebuilder's gray paint. Look pretty new with a re-plated cap/cover.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
07-24-2018, 05:02 PM | #4 |
Just remember that brake fluid is a dandy paint remover . . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
07-24-2018, 08:04 PM | #5 |
Moderator
Check out LMC link below for the Emission control decals you need...
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=180 |
07-24-2018, 10:21 PM | #6 |
I don't like rusty master cylinders either, but I gave up on painting them because any brake fluid you get on it takes the paint right off.
1968 SWB Step Side, Big Block, 4L80E , Running! |
07-24-2018, 10:39 PM | #7 |
"Paint's" nice unless your master is sketchy anyway. This is mine with Eastwood's High Temperature Stainless Steel Coating. Works better on the master than exhaust manifolds.
07-24-2018, 10:41 PM | #8 |
Some of the rust restorer stuff turns the rusty outside to black. Since its not paint it hangs awhile - can't remember brand I used.
07-24-2018, 11:17 PM | #9 |
07-25-2018, 01:42 AM | #10 |
