07-24-2018, 05:25 PM | #1 |
Known Header Clearance
So my LQ4 truck headers (just and I mean just) hit the upper frame rail.
I dont want to cut and reweld the angle on headers or cut the frame. Heres a link showing measurement. Anyone know of any decent "huggers" that have better clearance than this - especially at the flange position or near there (eg lower ) . Basically less than 4.5" furtherest point from header mount (inside) where it attached to head itself.
FAKKY 57 PANEL BUILD |
07-24-2018, 06:24 PM | #2 |
Re: Known Header Clearance
I used speed engineering ls swap shorty headers, all kinds of room and there cheep! Might not be the best for performance, but they fit great.
07-24-2018, 06:25 PM | #3 | |
Any chance you can grab a measurement.
07-24-2018, 07:47 PM | #4 |
I can grab a measurement this weekend, it's in a 71 c10
07-24-2018, 07:53 PM | #5 |
Thanks.
I ran out just now to buy some 2000 C5 headers - but they measured 5" also .... so basically the same as my truck headers. Looked like this https://www.ebay.com/itm/C5-Corvette...-/222695867830 Didnt think anything looked like it would have more clearance than that - but its really not the header tubes themselves rather the flange. So no beuno.
07-24-2018, 08:03 PM | #6 |
Thin the two speed engineering options are
https://www.ebay.com/itm/C-10-LS-Che...sid=m570.l1313 or these that go straight down - so less header tube - but thats a larger flange https://www.ebay.com/itm/LS-Universa...itleDesc=0%7C0
07-25-2018, 01:01 AM | #7 |
I'm running the top ones. I'll grab measurement when I get back to the truck this weekend.
07-26-2018, 06:09 PM | #8 |
A guy with a truck
Holley manifolds. Summitracing and CPP also have knock off versions
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-28-2018, 04:05 AM | #9 |
gen V Camaro may fit with no cutting, if you want a stock manifold that fits.
2010+ I can get a measurement for you
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 07-28-2018 at 04:11 AM. |
08-02-2018, 10:01 AM | #10 |
pics here...this is 2010 Camaro manifold mounted on my 71.
similar to your measurement, from head flange to outer point is just over 3 1/4" Maybe 3.5" the flange is 2 bolt vs. 3, which doesn't stick out so far.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
08-02-2018, 08:09 PM | #11 |
^^^ thanks for measurements and ideas on he GTO headers
I managed to get a set of 2005 GTO manifolds like these for 0.99c and $25 shipping on ebay. Will see if they actually arrive given the low price as well as fiment and clearance of the steering linkage/frame and trans. Hoping should be good.
08-03-2018, 01:10 AM | #12 | |
08-03-2018, 07:21 AM | #13 |
Dang it - that probably explains why they were so cheap.
For some reason I thought they would be the same (headers) or pretty similar based on manifold pics. I will be fabricating my own motor mounts most likely - so not sure if that will help ....... but otherwise Ill smack myself in the head in the head an look for some Camaro headers. Thanks guys !!
08-04-2018, 11:05 AM | #14 |
yes the GTO are totally different. I had several sets of those, scrapped them a while back.
the 2010 to 2015 camaro is what I have pictured. the camaro has that 2 bolt flange so it doesn't protrude out as far as the 3 bolt flange stuff.
08-05-2018, 12:48 AM | #15 |
I also tried a set of GTO manifolds with no success.
08-05-2018, 08:13 PM | #16 |
Thanks guys
Away in mountains with not much wifi access. Well - plenty of access just not by computer much. Ill post picks wehen I get back in about 7-8 days of the headers (GTO). If they dont work as it sounds like they wont ...... Ill check out trying to source Camaro headres for teh clearance - else go with the turn down ram style --- just due to not finding many offerings for camaro headers. Or at least a price ID like to pay https://www.ebay.com/itm/LS3-V8-EXHA...itleDesc=0%7C0
08-06-2018, 10:51 AM | #17 |
I have a spare set of gen 5 Camaro manifolds I can sell. Going rate on the Camaro forums is $75-100+shipping. You can PM me when you're looking and I can send pics if you want.
