07-25-2018, 10:37 AM | #1 |
Griffin Aluminum Pro Series Radiators
Just wanted to ask you guys if any of you have gone with the 26inch wide Griffin Aluminum Pro Series Radiators or were you able to fit the 31inch wide one.
https://www.summitracing.com/parts/gri-1-25221-x |
07-25-2018, 02:10 PM | #2 |
Re: Griffin Aluminum Pro Series Radiators
My suggestion would be to stay away from Griffen radiators. I had 2 of them from summit in my truck in less than 60 days and they both started leaking like a sieve. Luckily I was able to exchange it for another brand. Griffen epoxy welds and it doesn’t seem to hold up very well.
07-25-2018, 02:37 PM | #3 |
That sucks to hear, I have used them in several other car builds and never have had a problem with them leaking. That was about 10 years ago though so maybe there assembly or QC process has changed.
I guess my second question would be, is there any other budget friendly radiators or should I just plan on going with a Be Cool radiator. I guess the up side is it just drops in with the Be Cool and don't have to fab anything to fit. https://www.summitracing.com/parts/b...del/c10-pickup |
07-25-2018, 02:40 PM | #4 |
I haven’t dealt with a Be Cool radiator, but at least if you get it from summit it will have some sort of warranty and they won’t give you a hard time about exchanging it and shipping cost etc.
07-25-2018, 04:03 PM | #5 |
Old member
Agree stay away form them. I live up the road from them and want touch them.
I have gotten good radiators off e bay for cheap all aluminum welded.
07-25-2018, 04:24 PM | #6 |
I used a Champion radiator in an LS6 powered street rod that performed really well.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
07-25-2018, 05:08 PM | #7 |
I had a Be Cool radiator in my '63 Nova. Well made and worked well. Also had a Ron Davis radiator in my '73 Camaro, it was great. Well made and worth the $$
07-25-2018, 07:26 PM | #8 |
Moderator
I have Champion radiators in both my 72 and 68. They fit great and work great, would use one again.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
07-25-2018, 07:46 PM | #9 |
Junior Member
Same here two griffins went bad in one season I put entropy radiator and fans in
07-25-2018, 10:04 PM | #10 |
I'm using DeWitts all aluminum radiator from Summit Racing. Looks exactly like the original factory rad that came in my 69' CST396 truck. Working great so far.
