Old 07-25-2018, 10:45 AM   #1
66clow
66clow's Avatar
Speedo question
Trying to get my speedo working. I have a new cable, if I spin the end of the new cable it moves the speedo needle. I replaced the bullet in the trans at one point due to the seal and the gear looked ok. What else or what should I check? What test and how. Thanks.
66clow is offline   Reply With Quote
Old 07-25-2018, 10:51 AM   #2
notsolo
notsolo's Avatar
Re: Speedo question
Trans end plastic gear with square hole that the cable end fits in, not stripped out?
notsolo is offline   Reply With Quote
Old 07-25-2018, 10:52 AM   #3
demian5
demian5's Avatar
Re: Speedo question
Unscrew cable at speedo, drive, and verify the cable is turning. Then pull the bullet again and look and diagnose.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 07-25-2018, 11:08 AM   #4
66clow
66clow's Avatar
Re: Speedo question
Is there a way to pull a bullet without all the transmission fluid draining out? I guess maybe having the rear on jack stands?
Old 07-25-2018, 08:25 PM   #5
Bigdav160
Bigdav160's Avatar
Re: Speedo question
It shouldn't lose very much.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-26-2018, 11:10 AM   #6
demian5
demian5's Avatar
Re: Speedo question
Park with the front of the truck lower (like backing into driveway) and jack up from rear when doing it.
1986 C20 Scottsdale
Instagram: C10sofOC
