Shocks
Just changed my truck by adding 4" dropped shocks with the aluminum shoes under the axle, and now a shock relocating kit. My question is can I use the same shocks or should I buy shorter ones. There seems to be about an inch difference in the distance between the two. If I need new ones anyone have a preference and maybe a number. Thanks
Re: Shocks
Re: Shocks
Thanks, I appreciate your help.
Re: Shocks
Does that chart account for the relocated mounts? I'd assume that is all with shocks mounted in stock position. Would it be the same? i don't know but wouldn't think so. My truck has 4/6 drop and I want to get relocating mounts. So would like to know as well.
Old member
Best relocation shock mounts in my opinion on the market.
'No Limit' Relocator for the rears. You can do away with your rear sway bar afterwards to! ![]() http://nolimit.net/products#!/~/prod...32&id=26244502 Application: 1963-66 Chevy Trucks 1967-72 Chevy Trucks Description: If you are lowering your truck, or want it to ride better, moving the shock mount location can help. Our mounts move the shock outside the frame and behind the axle. The correct length shock to use is based on the amount of drop in the rear coil spring. We have two standard shock lengths for this kit. One for 0" to 4" dropped coils and one for 4" to 6" dropped coils. ** Not for coil-overs ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=688743
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
