07-26-2018, 07:31 PM | #1 |
Bed and cab
I have a 1967 chevy c10 and was wondering if anybody knows how to get the cab lines and bed to line up?The passenger is always higher when I look at c10s.see pic right in the middle.
07-26-2018, 07:34 PM | #2 |
Re: Bed and cab
New body bushings.
1970 Jimmy 4x4 IL6 1971 Jimmy 4x4 350ci v8 1971 SWB 327ci v8 1972 Short Stepside 305ci v8 1972 Blazer 2WD CST LS9 350ci 4sp 1999 4 Door LB 1 Ton Old Body Style 5.7 v8 |
07-26-2018, 07:38 PM | #3 |
Moderator
Re: Bed and cab
1/ Check the cab mount on passenger side...it may be collapsed and rotted, dropping that side.
2/ If this is a new build and someone put cab mounts in, they may not have set the height correctly... 3/ You can always add large washers between the top of the cab mount and floor to align the body lines.... 4/ Someone may have added replacement bed cross rails that are not the correct height... Just my initial thoughts... |
07-26-2018, 07:51 PM | #4 |
Re: Bed and cab
its a brand new build
07-26-2018, 07:59 PM | #5 |
Moderator
Re: Bed and cab
Make sure the body support rubber bushes are installed correctly and are not collapsed...if they are in good condition the only option is to add spacer washers between the top of the bushing and the floor....
This can happen when the floor of the cab and the body mounts were not setup correctly before being replaced.... Also...make sure the bed is tightened down fully on the passenger side front mount point...I have seen these bed twist enough to throw off the body alignment lines. |
07-26-2018, 08:09 PM | #6 |
Re: Bed and cab
ok I will check all parts are new.heres how I bought it all original and owner lol
07-26-2018, 08:13 PM | #7 |
Moderator
Re: Bed and cab
Interesting the body lines in that original pic are in line...pointing to some mis alignment during rebuild...
07-26-2018, 09:41 PM | #8 |
The Older Generation
Re: Bed and cab
If you added rubber pads between the frame and bed that would be your problem. They didn't have them from the factory..... LockDoc
07-27-2018, 11:41 AM | #9 |
Re: Bed and cab
Loosen the core support mounts and all the cab mounts, then lift the cab until it matches. Then shim everywhere necessary to make it snug again and re-tighten...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
07-27-2018, 12:52 PM | #10 |
Re: Bed and cab
weq92f what kind of Bed Cover is that?
07-27-2018, 01:19 PM | #11 |
Re: Bed and cab
It is a single, thick chunk of aluminum with a white backing that appears to be for insulation and dampening. A PO of the truck installed it and painted it to match. Unfortunately there are no markings or other identifying clues anywhere on it. It is a shame too as it's a real nice piece.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 07-27-2018 at 01:40 PM. |
07-28-2018, 05:12 PM | #12 | |
Re: Bed and cab
This what I had to do^^^. I installed a brand new Prothane bushing kit and had to shim the rear cab mounts and the front bed connections to get it all lined up.
For some people driving is one long series of corrections... |
07-28-2018, 06:06 PM | #13 |
Re: Bed and cab
the original pic if it could be blown up is a inch above the cab down the side
07-28-2018, 06:08 PM | #14 |
Re: Bed and cab
Iin the newest picture I just had rideteck 4 link set put in with coil over
