Old 07-27-2018, 02:08 PM   #1
2wdChevyblazer
2wd chevy blazer
Ok, I just put my 6.2 in and the ls engine mounts up perfect
The tranny doesn't look correct.
Do I need to change the yoke and the housing behind it ?
The rear end is from a 96 impala ss
Do I need the impala ss Drive shaft
Thank you
From Mr. Frustrated lol
2wdChevyblazer is offline   Reply With Quote
Old 08-01-2018, 03:29 PM   #2
YoungPup1977
Re: 2wd chevy blazer
Looks from the pics you first need to install your trailing arms and get a measurement from trans to yoke on the rear end than custom make the driveshaft. How ya get this far into the build without noticing the driveshaft requirement.
YoungPup1977 is offline   Reply With Quote
Old 08-01-2018, 05:23 PM   #3
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
you didnt show the rear end... but as far as the trans you can either go through the pain of a rear housing/shaft change... or just buy a custom drive shaft thats made for that connection...
http://www.driveshaftshop.com/domest...ece-driveshaft
This shaft is pricey... but contact him with what you have and what you are planning to do it with it and he will set you up with something realistic...
oh and your going to need a different crossmember that sits under the trans instead of behind... can you flip that one around?
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 08-01-2018, 05:39 PM   #4
chevyguy_72
Vintage Evil
this is out of my c10 with 6L90 PB frame brace/cross member/trailing arm mount... but you get the idea... there is a ton of space in there to fit any driveshaft style... the bottom is all one level... no drop like on your
Current Rides:
