Old 07-29-2018, 12:10 AM   #1
bautino95
Active Member
what should my a/c pressures be for r-12
I have an all stock 1971 402. The a/c blows cool but not cold. I have a few cans of r-12 laying around still .I did a search but can find what the high and low side pressure should be for a stock r-12 system. I have an old A/C book laying around and for GM with SVT it says low should be 28.5-31.5 and the high should be 210-260. does this sound right? Thanks
bautino95 is offline   Reply With Quote
Old 07-29-2018, 08:47 AM   #2
engineer_gregh
engineer_gregh's Avatar
Re: what should my a/c pressures be for r-12
Pressures are effected by ambient temperature, thats why you see a range in the numbers you've listed. I've gone through the A/C on my 71 big block truck, I converted to R134a. If I may make a suggestion, make sure someone hasn't put 134a in your truck previously before wasting the R12. FAA Benny is the A/C expert on the board.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 07-29-2018, 11:23 AM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
The numbers you quoted are close enough. You have a sight glass on your receiver-dryer. You can look for bubbles when the system is running. Bubbles generally indicate gaseous refrigerant leaving the condenser, which means low refrigerant level. It can also mean air in the system, though. What are your current pressures?
~Steven
Simi Valley, CA
Old 07-29-2018, 12:03 PM   #4
stormtown
How do I get hold of Benny? I would like to talk to him about restoring my 72 AC/heater box
stormtown is offline   Reply With Quote
Old 07-29-2018, 01:10 PM   #5
rx78nt1alex
rx78nt1alex's Avatar
Here's his FB.
https://www.facebook.com/factoryautoair/
1968 Chevrolet Fleetside C-10
1971 Chevrolet Fleetside C-10
rx78nt1alex is offline   Reply With Quote
