What spindles to install ????? HELP !!!
I have a 66 c10 with a disc brake conversion installed by PO, I am wanting to install drop spindles, most of the drop spindles require converting to 71-72 disc brakes or EQUIVALENT. My rotors are 1 1/4 thick , are they ''equivalent'', Will these fit my truck ? I don't want to just start throwing parts at this truck.
THANKS ![]() |
Re: What spindles to install ????? HELP !!!
I would go with spindles from the same company your disc brake kit is from to ensure compatability.
72 C10 lwb fleetside -stock 350/350 combo |
![]() Join Date: Aug 2004
All the 71-72 discs are 1 1/4.
The square body 73-87 HD brakes are 1 1/4. Tie rod end and ball joint tapers aren't the same between 71/72 and 73+. Figure out what year range spindles you have now, and go from there.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
These rotors requires different spindles, bearings and calipers. But I agree,... find what you have now via the balljoints and outer tie rods. (specifically the upper balljoint or outer tie rods,... since the lower balljoints are the same on 71-72 and 73-87 trucks)
Alright , Thank you guys for the knowledge.
