Old 07-29-2018, 10:11 PM   #1
tow rig
Drop hangers for 1970 GMC C2500.
I am having trouble finding a drop leaf spring hanger for my 1970 3/4 ton pickup. It has the HD rear leaf springs. They are the same 2.25 inches wide as the standard & C10 springs. There must be at least 5 different manufacturers making drop hangers for the 73-87 trucks. Does nobody make a version for the narrower leaf 67-72? (I am looking for a 4" drop in the rear, and do not want to notch the frame.) I have drop shackles and a set of "pancake" bump stops. The cab and bed are off of the frame. Does any one know where to get the drop hangers that I need?
tow rig is offline   Reply With Quote
Old 07-30-2018, 08:32 AM   #2
Mike C
Mike C's Avatar
Re: Drop hangers for 1970 GMC C2500.
Crown suspension:
http://www.crownsuspension.com/lower....25-wide-leaf/
DJM at Speedway motors (I have a DJM flip kit on back of my '69. ECE front setup)
https://www.speedwaymotors.com/DJM-S...op,351294.html
Summit has Classic Performance shackles:
https://www.summitracing.com/parts/c...up?prefilter=1
There are others as well. Western Chassis, McGaugheys, CPP I think all make shackles as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-30-2018, 09:27 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
www.earlyclassic.com also sells them
Keith
Convert to disc brakes.
Old 07-30-2018, 09:40 AM   #4
BlueBoy72
Active Member
Check these out at www.x2industries .com
Part number HNG-CHVC132 $175.95.
BlueBoy72 is offline   Reply With Quote
Old 07-30-2018, 12:31 PM   #5
tow rig
Thanks Blue Boy. That looks like what I need. Ordered a set today. I don't know why they chose to call them C10 hangers (C10 trucks have coils in the rear.) I think they could sell a few more, if they knew what to call them.
Old 07-30-2018, 12:42 PM   #6
lolife99
lolife99's Avatar
Not all C10 trucks were coil spring in the rear.
GMC trucks had more than Chevrolet,... but you could get them in both.
Keith
drop, hanger, leaf, lowering, shackle
