07-30-2018, 09:33 PM | #1 |
tach install trouble
Hey everyone,
I went to install a new tachometer as the previous one was not working. So i picked up an equus 6068 (black to match the dash a little better). Anyways installed everything, followed directions, and the RPMs were bouncing around between 4-5k at idle. Called theyre hotline and guy tells me it must be bad, return it and get another one. Went and hooked up the new one today and the same exact problem. Called the 800 hotline and he tells me to clean out the inside of the distributor. Just figured I would ask here, maybe someone has experienced similar. Between taking the gauge cluster out and messing with these tachs, I'm about 4 hours in and quite frustrated. Thanks in advance. Also, noticed this loose blue wire/socket from previous owner Last edited by SC1969c10; 07-30-2018 at 09:44 PM. |
07-30-2018, 11:09 PM | #2 |
Re: tach install trouble
Get rid of that Chinese junk and buy a Sun Rach
07-31-2018, 02:56 AM | #3 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Maybe you should take some spelling lessons? ...Which of the three tach signal hook up options are you using? Preferably #1, green wire to the (-) negative terminal of the coil. Make sure the tach is grounded to the firewall. Also make sure your battery is grounded to the motor, and the motor to the cab, and cab to frame! Follow the instructions for the red to switched power, and the white to the cluster terminal. Both are available on the fuse box...What distributor do you have? Is it an HEI with the coil built in? One last thing, most tachs have a switch for 4, 6, or 8 cylinder somewhere on the back, does yours? If none of the above works, you may be committed to using one of the inductive pick up options rather than the green wire to negative terminal on the coil...In other words, that tach may be a 6 cylinder tach...And rather than fuss with trying to mount it behind the cluster panel, just mount it to the column in front of the cluster...?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
07-31-2018, 07:58 AM | #4 |
It does have the adjustable cylinder option. Messed with that on the first one only to find out from the help line that they come out of the box ready for a v8. I went green wire direct to the distributor. Also tried the inductive to see if I was missing something, but that registered no RPMs. I will run through all the grounds, i know the only one im questioning is the tach is grounded to the metal gauge cluster.
The previous owner cut out a hole and mounted the tach in the center, otherwise I wouldnt have a problem mounting it else where. And i had to laugh as I knew someone would say something like that Posted via Mobile Device |
07-31-2018, 10:10 AM | #5 |
I would recommend hooking the green wire to the negative of the coil instead of the distributor itself, like you're thinking there maybe something odd going on with the dizzy and that's freaking out the tach. It should be a quick and easy transfer just to try it out and see if it works.
07-31-2018, 10:37 AM | #6 |
Appears to be an HEI dizzy, only one place to hook it up
07-31-2018, 11:01 AM | #7 |
07-31-2018, 11:04 AM | #8 |
I second that. If it already looks like you have the grounds there, check them for corrosion and replace them. I would also ground the motor to the frame with a hefty strap for good measure. I did it when I put my NVU gauges in and experienced the problem you are having: and it straightened right out. And anyway, adding and checking grounds is never a waste of time or money.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
07-31-2018, 05:21 PM | #9 |
Well i checked all grounds, everything was grounded by previous owner, so good on him. I even went and ran new grommets to make sure lines were secure. Checked tach, same deal. So i took the dash back out and grounded tach to the cab, still reading the same. So ran a wire from tach to battery ground and it jumped down 500 rpm idling at 35-4500. So for sake of experiment i took the ground of and the needle holds at 4000 then moves and stays still on 5, and then back to still on 4.
HEI distributor with a “idiot proof” spot for the tach’s green wire. Posted via Mobile Device |
08-01-2018, 08:28 AM | #10 |
Where did you connect the 12v power wire?
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
08-01-2018, 06:16 PM | #11 |
The previous owner had it spade connector’d into “cig” side
I went and switched it to the ign side and the tach didnt even register Now weird thing, in my frustration last night i left the key on and drained thebattery. Ive got a trickle charger on it and the tach is going from 0 to 8 back and forth as long as the chargers on, so its clearly getting power/feedback? Posted via Mobile Device |
08-02-2018, 11:48 AM | #12 |
Well!
After 30 minutes on the phone with summit support, we ran through everything thats been discussed here. Took the distributor cap off, all well there. Pulled plug wires and back on. Last step was to use the red button on the tach for cylinder adjustment. Suddenly it decided to work today and after adjusting it, shes running right! Maybe because its a day before my birthday, or the man upstairs felt bad for me, it finally worked. Thank you to everyone who gave me their input, I have no logical explanation, other than I did hook up a test light and the previous owner had it connected to a constant hot, so I switched it to IGN . But I cant make sense of why it didnt work last time I did that. Posted via Mobile Device |
08-03-2018, 02:35 PM | #13 |
Might have been stuck between 8 cylinder and 6 cylinder thus confusing the whole system and picking up signals for both versions at the same time.
